Page 15 of 41 FirstFirst ... 511121314151617181925 ... LastLast
Results 141 to 150 of 401
    May 2008
    #141
    mga experts, tanong lang..pano ba malaman kung sira yung computer box ng auto? habang nakalubog kasi sa baha, sabi nung nakakita bumukas na daw ilaw nya. yung inabot ng baha hanggang sa hood bale. kinabukasan (sunday), sinilip ko yung auto ko (lancer glxi 1994, napansin ko na di na gumagana alarm, keyless entry, tapos yung cd nakaeject, di gana stereo at ni walang ilaw pag turn yung key (di ko naman din start). so ang ginawa namin, tinanggal ko yung terminal ng battery, tinanggal ko yung tingin kong computer box nya, bukod sa konting linis kasi medyo maputik, tapos silip ko dipstick (may tubig), power steering (walang tubig), automatic transmission (walang tubig), break fluid (walang tubig). planning to have the car serviced by centennial auto (kaso busy ang lines nila).
    with this po, anu po pwede nyong maadvice na ipacheck ko sa repair shop? ang alam ko po kasi change fluids talaga to be sure, tapos pacheck ko din computer box, ano pa po kaya? please help po.. any advice din po kung saan pwedeng dalhin na repair shop (preferably may towing service kasi po di naandar yung car).
    thanks in advance
    Jul 2003
    #142
    mga bossing saakin din basa loob paano tangalin computer box ng civic FD. saka yung stereo nya hirap tangalin paano ba yun step by step? natangal ko na lahat yun nlng wala... pls help =D thanks in advance.
    Oct 2009
    #143
    guys me too.. need help please. i have honda civic lxi 96 model and same thing it was submerge in flood. good thing hindi inabot ang makina but the problem is yung computer box binaha ng husto at kinain ng putik
    any suggestions ?
    please contact me 09266490322 Ralph
    comments will be gladly appreciate
    please help please!!!
    thanks god bless
    Sep 2009
    #144
    My car is mitsubishi adventure model 2005. Originally, immediately after starting, warning lights appear on the dashboard including a yellow one that disappears after about two seconds. Now, after the car was submerged in floods and after I had it repaired by somebody, the car starts but gets off as soon as the yellow light disappears. Explanation was given by the repair man that the "menor" is high. Please give me your opinion on this matter. What could be the reason why it gets off along with the yellow light?
    Feb 2009
    #145
    Mga sirs, meron po ba rito na naka contact na sa wheelers? i've been trying for 2 days, walang sumasagot sa mga phones nila. tuloy pa kaya ang service nila o binaha din sila?
    Thanks.
    Aug 2004
    #146
    Even if they're still operating, they're probably swamped (literally) with calls. Try other, smaller services, instead. Go through the phonebook and try every one.
    As for all the ECU questions, you can attempt to clean them with contact cleaner. Check for any loose connections on the circuit board... if you left your battery connected when the car was flooded, you may have a capacitor or two that's busted. If you do. Tough luck... you'll have to find an electrician who can replace it.
    Be warned... if you are still under warranty, touching the box will void it. If you have AOG coverage... don't even bother... let the insurance company deal with it.
    Honda Civic FD: ask around on the Honda Club Philippines forums. Or you can call Speedlab (speedlab.com.ph)... they do piggyback ECU installs, so they'll know where it is.
    Advie... not a clue... do you mean to say it dies after starting? Please be clearer about this.
    Sep 2009
    #147
    Yes after starting the car the engine goes off. I am not sure if it's related to the yellow light on the dashboard that also goes off when the engine starts running. Normally, this yellow light would go off after starting but now as soon as this light goes off, so does the engine also. does anyone have any idea about this? pls. advise..tnx
    Aug 2004
    #148
    Quote Originally Posted by eight2five2000 View Post
    Diesel or gas? What does the yellow light look like? Is it spring-shaped or engine-shaped?
    May 2005
    #149
    Quote Originally Posted by gremz View Post
    post ko lang ... just incase na undeclared na "water damaged " yung kotse na binili ninyo eh pwede i rescind yung kontrata within a year.
    http://www.abs-cbnnews.com/lifestyle...maged-vehicles
    Not in the Philippines though.
    Feb 2007
    #150
    Maybe you forgot to drain the fuel and water seperator fuel filter, the yellow light will lit if there is water. and may me you should replace the fuel filter just to be safe.
NEED ADVISE: Vehicle/Engine submerged in flood water [MERGED]
