Page 6 of 7 FirstFirst ... 234567 LastLast
Results 51 to 60 of 68
    Feb 2005
    #51
    ako din may problem sa nanginginig na manibela, bago lang car namin, 2004 honda cr-v bought it feb 2005, pinapalit namin tires and wheels during feb din, yung problem is nanginginig na yung manibela pag umabot ng 100kph, nangyari lang to nung around april or may, slightly used lang yung car, every week lang cya ginagamit
  2. #52
    have you checked the alignment?
    Jul 2005
    #53
    alignment issue yan o balancing.. isa lang sa dalawa yan. pacheck nyo at iadjust para macorrect. kung tuloy pa rin ang panginginig e baka maluwag ang gulong nyo.
    Apr 2005
    #54
    last weekend, my gf's brother-in-law helped me lower my car's idle speed to around 900 (in-between 4th line & 1K). now i noticed nanginginig manibela when i'm idle in traffic. i can also feel vibrations coming from the engine especially when the a/c compressor turns on. any ideas? tia! --'98 corolla xe
    Feb 2005
    #55
    alignment issue, balancing? napa align na namin before after mag change ng tires and mags, ndi rin naman nalubakan ng matindi
    sa balancing ba? does it mean na ndi pantay tire pressure?
    tnx pala sa inyo for the inputs
    san kaya maayos mag pacheck around tondo or binondo area?
    #56
    Quote Originally Posted by maverick34
    hehehe...iba na ata ito. Idling problem naman ito. Please check if your idler up vacuum/switch works. Now back to Nginig...
    Mar 2005
    #57
    Quote Originally Posted by alwayz_yummy
    check your tie rod ends/ball joints....
    another culprit is camber alignment..
    and the last is your wheels are out of balance..
    think thats about it....
    yung toyota inova kong bago ganun di ang problem pag around 80-100 km then step on the brake, nag wiwigle yung wheels ko, sabi ng tyta que ave. wheel balancing daw , but after a week ganun pa rin ang problema.... what should i do? no problem naman sa wheel alignment...thanks in advance!
    #58
    wheel balancing, nagyari na din kasi yung panginginig sa akin before i thought i was going too fast, then i asked a friend true enought wheel balancing nga kelangan, add tingga lang oks na, but better have teh car check by a credible service center
    May 2004
    #59
    Quote Originally Posted by mattmatt
    ibalik mo na lng sa service under warranty pa yan kung hindi nila ma solve problem papalitan mo bka lemon yan
    Sep 2005
    #60
    as far as I know, basic causes are as follows:
    1. nginig when parked & idling - tune up problem.
    2. nginig ng converted RHD vehicles from Japan - lack of lateral bracing sa steering shaft.
    3. nginig at a certain speed - check wheel balancing first (wheel misalignment do not cause vibration, instead ay pumapaling ang takbo or uneven ang kain sa goma/gulong), if still vibrating check worned ball joint or tie-rod end or pit man arm, etc. (see mechanic at gas station or sa kasa).
Nanginginig ang manibela....
