Results 21 to 21 of 21
October 2nd, 2007 09:04 AM #21
Advice ko lang:
1. Check your fuel lines. Check your fuel filter as well kung clogged. Easiest way to do this is to disconnect your fuel return hose then check if fuel "returns" (get a bottle para hindi matapon yung gasoline) when your ignition key is turned on (for engines with electric fuel pumps). For engines with mechanical fuel pumps, someone needs to start the engine (redondo) for a few seconds para umikot ang fuel pums. Kung walang lumabas na gasoline sa return hose, either sira fuel pump, or clogged ang fuel filter, or clogged ang hoses, or worse, walang gas. He he he! Kung EFI, have your injectors cleaned, check for loose wiring connections, have the ECU checked or reset.
2. Check your high tension wires.
3. Check your ignition system (Pinakaimportante). Check kung upod na yung contact points, check kung loose yung connection and grounding ng contact point condenser, check kung tama ang ignition timing (baka sobrang advanced or sobrang delayed). Check the ignition coil baka loose and wirings sa terminals. If electronic, have the CDI checked.
4. Also check your air filter.
HTH!
Tesla Philippines
