Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Jan 2010
    buhayin ko lang ang isang dekadang thread na to. kumakalansing din yung altis ko, and it was found out that it was due to the muffler. inuga ng mekaniko yung ilalim and confirmed na nasa muffler nga nanggagaling yung tunog lata (same ng mga naririnig ko sa taxi). dinala ko rin sa gumagawa ng muffler, and confirmed the same thing. baka daw filter sa loob na bumigay na.
    1st mekaniko - suggestion is ipahiwa yung muffler para maikabit uli yung filter
    2nd mekaniko - suggester is to create a whole new assembly. pwedeng stainless (10, 500 pesos) or regular (5,500). di ko pa nakikita kung ano yung 'regular'
    any cheaper suggestion?
    Quote Originally Posted by itoangtama View Post
    if the muffler supports are not weak, meaning, hindi naman in danger of babaksak ang muffler, and you can live with the kalansing naman...
    i'd just leave it as it is.
    kung may butas yung muffler nyo, ipa-welding patch kaya..?
    but if you really want to get rid of the pr4blem, just replace the muffler, po.
    get a generic muffler, baka hindi ganyan ka-mahal yan.
    what about surplus muffler? i don't know, because i have never had the opportunity to use pre-owned mufflers.
    good luck, po.
    Jan 2017
    Mga Bro, baka may suggestion kayo dito sa problema ng oto ko. Pag maraming sakay (around 6 up) may nakalansing sa likurang ilalim. pag 4lang ang sakay (including driver ) wala naman. Ano po kaya ang problema nun?
    Thanks in advance!
    Lancer 2001 MX
    Apr 2009
    I suggest sa mga may kalansing just bring it to a muffler shop. madali nila masilip yan kung muffler ang problem. usually pag kalansing muffler na yan lalo na sa diesel na malakas mag vibrate , marining mo yung kalansing kahit naka idle.
    yung crosswind ko pag turn off engine narinig ko may kalansing dinala ko sa muffer shop, nakita may butas na flexible pipe.
    Dec 2016
    Quote Originally Posted by anthon05 View Post
    I suggest sa mga may kalansing just bring it to a muffler shop. madali nila masilip yan kung muffler ang problem. usually pag kalansing muffler na yan lalo na sa diesel na malakas mag vibrate, marining mo yung kalansing kahit naka idle.
    Buhayin ko lang din ito as this is the closest thread sa problemang napapansin ko ngayon sa sasakyan ko(suzuki dzire 2013 mt). I was able to record the sound, if you would only spend some time to listen to it baka sakali matukoy nyo base sa sound lang. Rattling sound(tunog lata!), kapag tumatakbo in low rpm the first time i use my car in the day, mas dinig ko siya sa loob unlike pag binuksan ko yung bintana di ko lang sure kung sa harap, ilalim o likod, narerecreate ko siya minsan pag hindi pa mainit makina pag naghalf clutch, eventually nawawala din pag malayo-layo na natakbo at maririnig ulit minsan pag brake before shifting to lower gear pag mabagal. Eto yung mga narecord ko(pasensya na if vid,malaki or what):
    rattlingsound0:3-0:7seconds
    rattingsoundinthelast4secondsofthevideo
    Nabasa ko na yung mga possible causes from other concerns dito sa forums, baka lang maspecify after hearing the sound. Sa mga nagpagawa sa thread na ito, did you encounter the similar sound?ano sa mga solutions tinake nyo nakapagayos?
    Hingi lang ako opinions medyo hindi ko pa din maisip pano idedescribe kapag pinatingnan ko, baka hindi din marinig yung nirecord ko sa cp, unless marinig kung itestdrive, TIA/TYVM.
    <help emoticon> di ako magamit ng emoticon bat ganun? ehe. <wonder emoticon>
    Dec 2016
    Quote Originally Posted by susikey View Post
    Up ko lang to mga sir pls help. Baka kasi delikado na pagbyahe ko dahil dun sa naririnig kong sound, di ko pa kasi napatingnan pangilalim ng sasakyan ko e or transmission/clutch. napaparanoid ako.
    Mar 2017
    Pacheck mo nalang asap sir sa shop na may lifter o maski sa gas station service shop. Usually may maluwag yan. Mahirap naman kapag bumitaw o kumalas sa byahe hassle na talaga.
kalansing
