Results 11 to 20 of 23
July 11th, 2005 09:46 PM #11
Sa Caltex MIA, if you don't use their flushing oil, they will forfeit the "warranty" of their work which is 6 months.
July 11th, 2005 10:38 PM #12
...flushing oil? iba ba to' sa sobrang langis from the last oil change? i just use the excess oil from my last oil change to flush the oil. i dont even bother flushing it.
July 11th, 2005 11:50 PM #13
Originally Posted by Shadetree MKNX
also...prevention is ALWAYS better than a pound of cure...
- Jun 2005
- 113
July 12th, 2005 02:00 AM #14Originally Posted by ILuvDetailing
I doubt if anything bad is really going to happen as a consequence of skipping the "flushing oil"... unless the mechanic gets wise on you and puts something into the engine behind your back.
Besides, if anything bad did happen to the engine within the given time period, I doubt they would actually shoulder the repair expense, instead of simply offering an oil change service free of charge for both labor and materials.
- Jun 2005
- 113
July 12th, 2005 02:15 AM #15Originally Posted by pitbullz
I was just wondering why it would be necessary to save the "fresh" oil which was used to "flush" the remaining gunk from inside the engine.
A friend of mine (he worked as a mechanic in his dad's shop while finishing an engineering degree, so he did know a lot about cars) once told me it wasn't always a good idea to use flushing oil (especially on an older engine) because it would remove old gunk from around the oil seals, causing them to leak later.
- Dec 2003
- 11
July 13th, 2005 07:14 AM #17
Originally Posted by dyake04
i think its not good same as the flushing oil ..
it will have a bad effect on the bearing
once it will get inside on the engine
since you cant remove 100 %..the kerosene or flushing oil
there are some residue of it even if you drain
- 299
July 13th, 2005 07:26 AM #18may kerosene component daw yung ibang pang flushing. advise nung ibang mechanic kung talagang dirty na yung oil at pagkalaput-lapot, lagyan ng bagong oil yung pinaka mura, then drain/change oil after patakbuhin ng ilang kilometro. or pwede rin kinabukasan na i-drain tpos mo i-byahe.
- Dec 2003
- 11
Tesla Philippines
