Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Apr 2005
    Quote Originally Posted by Autobeat
    Had a similar experience with our CRV. It was due to a busted auxiliary fan in our case.
    your temp was going up too when in traffic?
    my radiator fan is working tho when we check it, just not sure if it stays working while on the road...should i replace it?
    Nov 2003
    a warped head/headgasket will result in water loss.
    Apr 2005
    Quote Originally Posted by speedyfix
    i see, i just found it weird that the temp goes down when car is in motion and goes up when in traffic...i'll have the shop do a compression check to check out head and gasket...thanks
    Teej55,
    One rule of thumb in overheating (not all the time, but most of the time) is when in traffic, the temp goes up, and when in motion, returns to normal is problem in the thermostat (meron naman siguro CRV). But of course, check muna water sa radiator after it cools down (cold to touch yung top of radiator).
    Quote Originally Posted by teej55
    In what we experienced when the fan was busted, yes temp was going up during traffic, then manageable temp already when cruising. But if you tested that your fan works then it may not be the problem. To verify, you can run the CRV, if the temp starts to go up, but the fans are all turning, then you can rule out the fan. If the fan does not start up while temp is increasing, then the fan may have a possible problem.
    I agree with autobeat,save yourself with a lot of expense,forget the compression test thing. im sure one of your radiator fan is busted. Dalawa ang fan yung isa smaller for the aircon and the bigger one for the radiator. bka yung isa busted. Did you also notice na medyo mahina ang cooling efficiency ng aircon mo?
    Aug 2005
    pwede din thermoswitch ang problem usually pag di umaandar yung fan.
Help with my Honda CRV
