Results 1 to 10 of 18
March 2nd, 2004 10:55 AM #1
hey guys... my dad's CRV year model 2000 is nearing 40,000km already.
besides change oil, oil filter, transmision oil.... is there any other things i should do?
should i replace spark plugs already? (never been replaced)what else?
what other fluids should i replace?
what should i lubricate?Last edited by dieselNUBI; March 2nd, 2004 at 11:01 AM.
March 2nd, 2004 11:00 AM #2
whaaat? spark plugs never been replaced at 40,000 kms? imho, diba dapat every 10k ang palit ng plugs?
other things you might check:
a) radiator flush
b) brake fluid replacement
c) power steering fluid replacement
d) tire rotation/balancing/camber check
e) aircon cleaning/check
f) air filter replacement/check/cleaning
dami pa....
March 2nd, 2004 11:05 AM #3
tenks happy gilmore! better get my pen n paper!
ano pa?
pansin ko kasi loss of power na eh. parang humina na ang pulling power nya.
- 10,620
March 2nd, 2004 11:21 AM #5
kasi sa manual its the usual. change this change that?
how about lubircating? of course mdyo naluluma na tsikot kelangan grasahan ulet kung ano man dapat grasahan.
March 2nd, 2004 11:26 AM #6
erap, suggestion lang...
why not bring it to honda mismo for a heavy PMS? i know it can be expensive, but it is worth it...
March 2nd, 2004 11:44 AM #8
IMHO,
to have your car properly maintained, bring it to the casa every 10K. then you can DIY the maintenance in between.
also, check your manual. usually at 40K there is not much to do other than the normal PMS routine. oil, oil filter, air filter, coolant, battery water, brake fluid, alignment, fuel filter, spark plugs, etc
for the spark plugs, have it checked if the CR-V is already using the denso iridium plugs. AFAIK, the Cefiro and Rav4 is already using those and needs replacement only every 100K.
March 2nd, 2004 11:49 AM #9Originally posted by dieselNUBI
madugo kasi eh. okay sana kung makakatipid ako kahit konte.
March 2nd, 2004 12:06 PM #10Originally posted by Ungas
Kung gusto mo makatipid, follow the procedures in your manual pero sa talyer or gas station mo dalhin.
Tesla Philippines
