Results 11 to 20 of 24
    Nov 2003
    check the starter or at least have it cleaned
    Aug 2003
    hard starting? does it crank? if so, most probably fuel supply problem. get that fuel filter replaced would be a good first step.
    if it doesn't crank.. weak battery, bad starter, starter solenoid..
    Update Ko lang po
    Ok naman yung batteries 12.9 volts pa, napansin ko lang pag ayaw mag start pag ipu push back mo yung servo ng aircon na tumutulak sa gas umaandar na siya ( habang may isa pang tao nag turn ng keys and tapak sa gas ), twice na nangyari
    related po kaya o natsambahan ko lang wala pa kasi akong masyadong alam sa gasoline engine
    kung ito nga po paano ba ito na rerepair
    thanks in advance
    Aug 2005
    fuel filter and fuel pump ata yan.. eh pra ayaw mag bigay ng gas kaya ganun. IMO lng
    Jul 2006
    Quote Originally Posted by LHV View Post
    I just bought a sentra last week, 92 model, it was in a very good condition but problem is at times it wont start, it would just crank, this would happen 1 out of 4 instances, napa carb cleaning ko na siya sa rapide, then next day tune up sa servitek pero naulit na naman
    actually nung tune up puro kalawang na yung fuel filter, isa ito sa pinagdududahan ko, how much po ba sa palinis ng gas tank,
    o may iba pa kayang cause, kasi minsan one click naandar na then pag pauwi ka na from the mall patay ayaw umandar, kailangan may mag start ng key then choke ko yung carb
    please advise, thanks in advance
    Obviously may problema somewhere sa fuel system ng car..kung ok na ang carb, check the fuel pump tipong malapit ng bumigay ito dahil sa sinasabi mong ichoke pa para umistart.Then maari ding sa fuel tank baka nga madumi or sa fuel line. If you found out that the fuel tank is faulty, linisin mo ang buong fuel line at siyempre ung carburetor ulit.....good luck!
    Jan 2004
    check fuel filter pati na rin spark plugs. pati timing.
    Nov 2006
    baka fuel pump problema nyan,try mo gawin to,kung ayaw mag start ng kotse mo,have somebody to crank the engine sabay hampasin mo ng malakas ang fuel tank,as in malakas na malakas, kung umandar ang kotse mo eh fuel pump ang problema,ang mangyari kasi sabi mo may kalawang na yung fuel filter,marahil barado na rin yung fuel pump,at paghinampas mo yung tanke kakalog yung fuel pump(kung ang pump ay nasa loob ng tanke)matataktak yung mga dumi at para makapasok yung fuel,,,,if yun ang prob,palitan mo na ang pump sabay palinis ng tank.
    Jul 2006
    Mukhang naka ilang buwan na rin yung thread, sana naman by now na-start na yung Sentra
    Nov 2006
    oo nga,eh kasi hindi naman inupdate ng may problema kung ok na ang car or fix na yung problema,sana if you have a car problem(ignition,etc..)iupdate nyo naman if ok na or di pa para di naman pabalikbalik ang thread,...
    Nov 2006
Car wont start
