Results 11 to 20 of 65
June 27th, 2012 06:08 PM #11
Try advance techniques, its near your place plus they specialized with sentra modifications
July 7th, 2012 01:20 AM #12
idle bomb ang problema mo sir ang kadalasang pinanggagalingan nyan IACV, Faulty ECU MAF, Vacuum hose leaks...
btw, ingat lang sa paglilinis ng TB mo dahil very sensitive yung MAF sensor kung lilinisin mo ng carb cleaner make sure na medyo may distance dahil masyadong manipis yung mga filaments nung maf napakamahal ng replacement ng maf sensor natin 22k ang original sa nisway auto parts sa may ligaya and mahirap maghanap ng surplus.. HTH...
July 15th, 2012 08:06 PM #13
may alam ba kayo sir kung san maganda magpalinis ng mga yan and mapa check narin kung may leak vacuum hose ko?? hindi ko makita yung advance techniques.. hehe
July 15th, 2012 08:43 PM #14
Sa facebook search mo yun advance techniques, you can also check their location thru their facebook page
July 15th, 2012 10:22 PM #15
ayun, sa wakas... maraming salamat sir aki0125.. sana maayos nila kotse ko.. god bless you po
July 17th, 2012 09:39 PM #17
kung las pinas area kayo. yung shell sa tapat ng perpetual ay naglilinis ng TB and MAF...
fyi lang po..
August 1st, 2012 12:06 PM #18
ok na ba oto mo sir? santolan pasig ka lang pala lapit lang nyan dito samin kayang kaya ng diy paglilinis ng TB sir! anong st. ka lagi kasi ako dumadaan dyan sa santolan?
- May 2006
- 3
August 9th, 2012 02:27 PM #19sir, regarding this idle bomb, un din ung prob ng series3 ga16dne automatic tsikot ko... tried cleaning the tb na... setting base idle and timing lang kulang... cno po ung may alam dito how to set base idle at timing ng GA16dne? ang nakita ko lng sa net kay ung GA16de
August 9th, 2012 03:00 PM #20
try mo lang disconnect ang batteries overnight para mareset computer then the car will relearn everything when you use it in the morning.
medyo complicated ang pagset manually you will need to remove the tps and auxilliary fans before setting the rpm. I found out na mas madali yung reset ang ecu by disconnecting the batteries.
Tesla Philippines
