Results 1 to 10 of 65
June 25th, 2012 01:03 PM #1
hello mga sir.. newbie here..
tanong ko lang po sa mga master dito..
after driving 30mins or so pag nakastop ako kunyari sa red light o kaya traffic bigla nag sha-shake yung kotse ko tapos yung rpm bumababa sa 500 or lower tapos tataas ulit sa normal tapos bababa nanaman ulit.. pero hindi naman namamatay yung makina.. then after a few minutes of driving ulit hindi na sya mangyayari.. nung isang araw lang nagsimula to eh.. ano kaya problem nito?? sabi ng kapitbahay ko tune-up lang daw.. pero gusto ko muna makuha opinion ng ibang tao bago dalhin sa mekaniko para may idea ako kahit papano..
nangyayari po sya kahit naka-on or off ang aircon..
June 25th, 2012 02:19 PM #2
June 25th, 2012 02:41 PM #3
pardon my ignorance sir, do i have to change my engine oil and oil filter everytime na mag papatune-up ako?? sabihin ko din sa mekaniko linisin throttle body..
June 25th, 2012 05:21 PM #4
MAF/Throttle body cleaning..
for Nissan B14s, its part of the preventive maintenance.
I do it every six months or when needed - DIY mode.
regarding your question above that you change your oil and filter every tune up, not necessarily. follow the oil change intervals, which depends on the oil being used.
June 25th, 2012 05:27 PM #5
i doubt sir if your oil has anything to do with your problem. basta tama ang oil level, i think wala kinalaman yun.
i saw your other post and a fellow tsikot member suggested the MAF sensor replacement.
its up to you na sir, first hand experience kasi sya, same model pa.
tune-up and paglinis ng mga dapat linisin ang inuuna ko
before replacing.
to each his own.
June 26th, 2012 12:29 PM #6
thanks sa mga sumagot.. hanap pako maglilinis MAF sensor and throttle body ko.. palpak lakad ko kanina sa shell eh at hindi ko kaya mag DIY.. hehehe
- Jan 2008
- 4,726
June 26th, 2012 12:31 PM #7madali lang linisin yung MAF.. just remove it tapos spray ka ng carb cleaner... yung throttle body din.. medyo madami ka lang aalisin...
btw, take note nyo yung mga position ng sensors... lalo na yung TPS.. kasi pag na iba yan may effect sa engine performance
June 26th, 2012 12:43 PM #8
wala po ako alam sa makina sir eh.. hehehe.. hindi ko alam kung san nakalagay yung MAF and throttle body.. at higit sa lahat wala akong tools and panglinis.. nyahaha!
- 53,883
June 26th, 2012 04:11 PM #9my sentra's engine used to die when decelerating from hi speed into idle speed. i read an article from somewhere, which recommended a shop along banawe... i brought it there, and saw a good number of hi-performance nissans.. the mechanic was kind enough to have a look. he told me, "sakal po ang idle air screw." he opened it a little and the car was ok na. and he didn't charge me.
i'm afraid i forgot the name.. perhaps one of the readers out there knows the place.
June 27th, 2012 10:14 AM #10
swerte nyo sir..
baka po may mai-suggest kayo kung san maganda magpalinis ng MAF sensor and throttle body ng b14 ko.. TY..
malapit po ako sa santolan pasig
Tesla Philippines
