Results 11 to 20 of 32
- May 2015
- 16
July 8th, 2015 10:59 PM #11
- Mar 2014
- 901
July 9th, 2015 07:45 AM #12
July 9th, 2015 08:40 AM #13
Stop guessing and hoping. Check the intake manifold vacuum with a gauge and observe. A good indication is between 17-21 inHg(inches of mercury). If it slowly drops and the engine stalls, it is for sure plugged exhaust system. With it too, hook up a fuel pressure gauge. Fuel should read around 40psig at idle
- May 2015
- 16
July 9th, 2015 10:49 AM #15
Do a proper diagnostics. The results should answer yes or no, on or off or in numbers of measurement. Avoid maybe, sort of, "baka" and the anecdotal "ganyan ang nangyari sa kotse ko". Remember, not all situations are the same, not all cars are the same therefore solutions are not all the same
- Mar 2014
- 901
July 9th, 2015 11:13 AM #16
- Mar 2014
- 901
July 9th, 2015 11:19 AM #17
- Mar 2014
- 901
July 9th, 2015 11:31 AM #18Your fuel lines... Form tank, through fuel lines, to fuel filter before coming into fuel rail injectors. You just had replaced your fuel filter and also your fuel pump at the tank. When you start your car and runs. Do you let it run at idle, observing, and when reaching 10 mins, it stalls or stops?
Sent from my UP+ using Tapatalk
- May 2015
- 16
July 9th, 2015 02:50 PM #19
July 9th, 2015 02:59 PM #20
What are the stats and parameters? You can keep writing about the symptoms but it will never fix itself
Tesla Philippines
