Results 1 to 10 of 18
    Apr 2010
    good day mga bosing, ano po problema ng clutch system ng sentra FE ko kasi matigas sya apakan at parang may sumasalat pag ipapasok sa 2nd gear? meron din pong shock shift pag bitaw ng accelarator pedal hindi po sya smooth shifting. sabi po ng tito ko baka daw di genuine parts yung nilagay sa clutch parts kaya daw matigas, any advice po mga sir? ano po dapat palitan or iadjust? or need lang po ba ng lubricant? sentra Fe po yung oto at nakuha ko lang po 2nd hand, thanks
    The hard clutch pedal could be sign that the clutch cable needs to be either lubricated or replaced. Also possible the cable used was a "replacement" cable.
    The jerky clutch might mean the clutch needs to be broken in (break-in for a few hundred kilometers) for smoother engagement.
    Apr 2010
    thank you sir, i will try to put some greasing or lubrication to the cable clutch but do you think sir there is nothing wrong inside the clutch assembly? like release bearing or pressure plate to make it more lighter? by the way sir, is it ok to put singer oil for the cable?
    paps after some greasing or lubrication check mo yong pagkakalagay ng clutch cable dapat di nakaipit or masyadong liko, dapat malaya syang makakagalaw kasi minsan nangyari yan sa akin after ko magpalit tinalian ko ng plastic tie wrap yon ang tigas apakan ng clutch ko nong tinangal ko yong tie wrap tapos inayos ko yong pakakabend nya lumambot na clutch ko. sana makatulong..
    Jun 2009
    Is the Sentra FE cable type? Better check, I understand this is hydraulic type.
    Apr 2010
    Quote Originally Posted by nickriingen View Post
    sir, mine is cable type clutch, 98 mdl. I think 98 and 99 mdls are cable type. 2000 up are the hydro type. or im not sure what year mdls are the hydro type
    Apr 2010
    Quote Originally Posted by Jakk View Post
    thanks sir, subukan kong kalasin yung cable baka nga na bent yung wire nya kasi pag inaapakan ko may tumutunog mismo sa cable parang di sya free. parang na twitwist. hope yun nga ang cause. di ko pa kasi maalis kasi nagamit ko pa yung oto. will get you an update pag na greasan ko na at naibalik, thanks again
clutch problem on sentra FE
