Results 1 to 10 of 18
- Apr 2010
- 97
April 1st, 2010 06:16 PM #1good day mga bosing, ano po problema ng clutch system ng sentra FE ko kasi matigas sya apakan at parang may sumasalat pag ipapasok sa 2nd gear? meron din pong shock shift pag bitaw ng accelarator pedal hindi po sya smooth shifting. sabi po ng tito ko baka daw di genuine parts yung nilagay sa clutch parts kaya daw matigas, any advice po mga sir? ano po dapat palitan or iadjust? or need lang po ba ng lubricant? sentra Fe po yung oto at nakuha ko lang po 2nd hand, thanks
April 1st, 2010 06:41 PM #2
The hard clutch pedal could be sign that the clutch cable needs to be either lubricated or replaced. Also possible the cable used was a "replacement" cable.
The jerky clutch might mean the clutch needs to be broken in (break-in for a few hundred kilometers) for smoother engagement.
- Apr 2010
- 97
April 5th, 2010 10:45 AM #3
thank you sir, i will try to put some greasing or lubrication to the cable clutch but do you think sir there is nothing wrong inside the clutch assembly? like release bearing or pressure plate to make it more lighter? by the way sir, is it ok to put singer oil for the cable?
- Feb 2008
- 76
April 5th, 2010 11:06 AM #4paps after some greasing or lubrication check mo yong pagkakalagay ng clutch cable dapat di nakaipit or masyadong liko, dapat malaya syang makakagalaw kasi minsan nangyari yan sa akin after ko magpalit tinalian ko ng plastic tie wrap yon ang tigas apakan ng clutch ko nong tinangal ko yong tie wrap tapos inayos ko yong pakakabend nya lumambot na clutch ko. sana makatulong..
- Jun 2009
- 325
April 5th, 2010 12:08 PM #5Is the Sentra FE cable type? Better check, I understand this is hydraulic type.
- Apr 2010
- 97
April 6th, 2010 06:00 PM #6thanks sir, subukan kong kalasin yung cable baka nga na bent yung wire nya kasi pag inaapakan ko may tumutunog mismo sa cable parang di sya free. parang na twitwist. hope yun nga ang cause. di ko pa kasi maalis kasi nagamit ko pa yung oto. will get you an update pag na greasan ko na at naibalik, thanks again
- Apr 2010
- 97
April 6th, 2010 06:06 PM #7
- Apr 2010
- 97
April 8th, 2010 06:14 PM #8mga bosing, ok na clutch pedal ko ang lambot na, what I did is to disconnect the entire cable from the pedal. ang hirap lang umilalim sa floor, ang hirap matanggal yung cable unless alisin yung buong pedal, napansin ko na tuyong tuyo yung grease ng cable kahit hilahin ko ang tigas gumalaw. then i put some wd40 until mag flow sya from top to bottom holding the cable vertically then try koi push and pull until I notice na madali ng hilahin back and forth. so nung binalik ko na, ang lambot na ng pedal parang naka hydro hehe. thanks po sa mga advice nyo. akala ko release bearing na or clutch plate na, thank you again and more power to all
- Feb 2008
- 76
April 9th, 2010 01:29 PM #9paps sarap ng feeling kapag naayos mo problema ng kotse mo na kaw ang gumawa di ba?:barmy: :barmy::barmy:hehehe.
Tesla Philippines
