Results 11 to 20 of 31
October 1st, 2009 03:41 PM #11
^ I know gasoline or diesel will dissolve paint... but definitely not within seconds. It appears like your paint has almost no clear coat. Typically, when fuel is left to dry on a painted surface, all that'll usually leave is a nasty stain that can easily be buffed off with polishing or rubbing compound. It shouldn't even reach the base coat.
- Aug 2009
- 1,553
October 1st, 2009 09:01 PM #12the revo with ppg ceramiclear paint was left on for about a good 3 to 5 minutes since the gas boy took some time looking for a rag, and im sure it still has clear coat since i had it 2x coated, when he did wiped it, it was already nearly dry and when he did, some of the clear coat went with the rag exposing the base coat, the weird thing is when he wiped it dry it was still smooth to the touch, but when i got home its like blisters formed on the clear coat and base coat making it really rough
as for the camry, what happened was the gas boy dropped a few drops in the paint, i managed to dig out some used fastfood napkins about 30 seconds in my car and wipe it down, when i got back home i saw the dropped spot whiten since my car was black so its definitely noticeable, i was hoping to buff it out that weekend with a polish and a wax, so i started to wash my car, and went on with claying until i noticed its like a part of the dropped area peeled off, thats when i noticed the dropped part was already bulging with water inside like a huge blister
oj88: you mentioned it should be easily buffed off with polishing or rubbing compound, although i know the diesel definitely ate through the base and with me being very upset with ppg ceramiclear, im planning to try to smoothen out the areas around the damaged base coat since it has some really rough spots around it (more like blistered clearcoat) at least to make it a little bit more presentable and at least try to hide the defects. im assuming you have encountered this before, could you recommend some products that are good for polishing and removing these rough spots? and do you think wet sanding the area's around the damaged basecoat (not the damaged basecoat-wouldn't want to add more damage) would be a great idea? its been months now and im a bit scared of touching the area or even polishing out the rough spots
October 1st, 2009 09:15 PM #13
October 1st, 2009 09:22 PM #14
^ Sorry if I seem to appear an expert on the subject, but I'm really not. These has all been from previous experiences (ie. gas boy took out the nozzle too early while it was still dripping, the auto-stop failed to work, etc.) All of which never left any permanent marks on any of the cars I've owned. If there were any visible residue, it was easily removed by washing or for the more stubborn ones, some localized buffing.
For tips on how to restore the surface, try this site: http://www.howtocleanstuff.net/auto/...from-vehicles/
- Aug 2009
- 1,553
October 1st, 2009 10:34 PM #15hmmm i wonder what ever made things worse in my case then, i hope you guys don't think i'm exaggerating, i'll try to get some pics tomorrow, i already had the lower part of the gas tank spot paint repaired but im still saving for the spot paint repair for the lower fiber glass part.
would it have something to do with the PPG ceramiclear paint? both cars have it-just a thought, i had it put on both cars simply because i got tired of our cat always scratching the hoods and the local carwash boys swirling it when we have it washed
oj88: thanks for the link, this will be very helpfull at least now i know its gonna be ok to wax and polish the paint, i'll try this and give it a shot once typhoon "pepeng" clears out, i hope this could at least smoothen out the rough parts. if i still can't get it off i'll try wet sanding then, and if i still can't smoothen it up i guess i have no choice but to have it done outside
October 2nd, 2009 12:02 AM #16
buy MarkV citrasolv. citrus based solvent for asphalt removal.
sa mother's HQ san juan meron. around 600 pesos
October 2nd, 2009 12:50 AM #17
Just kerosene will do, works for me.. I just put it in a spraying bottle and spray it in the affected area... you will see the asphalt drifting together with the kerosene.
October 10th, 2010 12:09 PM #18
October 10th, 2010 12:16 PM #19
Yup, Kerosene nga ang pinakacheapest and isa sa pinakaok na pang tanggal ng asphalt. nadidisolve kasi nito ang asphalt. Ito din and hinahalo sa rubbing compund dati pag nagpopolished sa painted area.
- May 2008
- 123
October 10th, 2010 01:07 PM #20light spray with WD40 let it soak for a few minutes then wipe off. paint looks like its been waxed and repels crud for a few days.
