Results 11 to 20 of 30
    Feb 2005
    Sa ibang gas station, like caltex along marcos in Marikina, they use some other kind of undercoat parang clear type daw. I never seen it though. Yung ibang tao ayaw ng rubberized undercoat kasi pag pangit yung gawa doon pa daw magsisimula yung kalawang. If there are any air pockets or areas where water gets trapped. Some accidentally apply it to parts that should not be coated like the shocks...
    Mahirap din daw tanggalin yung rubberized coating if you want to redo it, can anyone confirm?
    on the pro side, water proofed, reduced cabin noise since the rubber softens the impact of things hitting the under side.
    Aug 2008
    Quote Originally Posted by a9828 View Post
    is undercoat same as rustproofing? how often should this be done? also, paglabas ng unit sa casa kapag brand new di ba dapat na-apply na yan? thanks
    undercoat is just a part of rustproofing......pag rustproofing marami yun...undercoat plus kasama pinto, hood, etc.....pag undercoat, yung pang ilalim lang
    Feb 2013
    Quote Originally Posted by homhomnova View Post
    I would recommend Dallas along T. Morato.. 3M ang brand at maayos naman gawa nila.. pwede mo pa sabihin sa gumagawa kung meron kang area na gusto mong pakapalan ang undercoat.. yung tatlong kotse namin dun ko pinapagawa.. so far 3 years na yung undercoat maganda pa rin..
    sir homhomnova magkano kaya sa montero
    Quote Originally Posted by jayhan1820 View Post
    depende yan kung ilan gallons magagamit na materials
    Feb 2013
    doon kc sa loob ng casa may zeibart doon...ask ko mag kano sa montero...nasa 4700 daw...undercoating lang..
    kc kng same lang din sa Dallas ...i think mas oky na din sa ziebart...what u think..???
    God Bless..!!!
    ^ iyong sa fd nga 3550 na sa suki kong customer's cradle. pero worth it naman for me kasi ok at pino ang trabaho nila
    btw, napansin ko na na-reduce ang nvh kapag magpa-undercoat. definitely may obvious difference sa reduction ng road noise
    Jan 2013
    God Bless..!!!
    usually 1 gallon lang ok na yun.. makapal na ang coating nun.. 3k or 3.5k yata nung magpa undercoat ako 3 years ago.. kasama na underwash nun.. pero kelangan bantayan mo din at patakpan mo ng maigi yung dapat na takpan like shocks, transmission, propeller, etc, etc..
    Feb 2013
    thanks sa lahat na info..
    I've called
    Petron Kanlaon: 1600 Labor only w/underwash. Add for gas usage.
    and Petron Car Care Center in D. Tuazon (Wilson and Jackson) : 1.5k labor w/ underwash and gas usage.
    1350 yung bili ko dun sa isang gallon ko na 3m undercoat. Sobra sobra pa yun para sa vios, pang touch up nalang yung sobra, or pwede ko pakapalan
    Quote Originally Posted by ronki View Post
    I've called
    Pwede na IMO. Patakpan mo na lang ng dyaryo yung ibang parts suspension and brakes. Pagawa na habang summer.
undercoating
