Results 41 to 50 of 92
- Dec 2012
- 13
March 27th, 2013 05:58 PM #2
Diesel engine oil turning black means
the oil is working to absorb all the sulfur and other by-products of combustion. The manual does specify a 10k kms oil change though major Philippine practice is every 5k kms. Mitsubishi casas practices 10k kms oil change for synthetic diesel engine oils with a requirement for a 5k km oil filter change.
March 27th, 2013 06:17 PM #3
March 27th, 2013 06:53 PM #4
No question as Mitsubishi OEMs is still the Best. But in my search of the most cost-effective maintenance for my Monty (mahal PMS sa casa) I turned to aftermarket filters which are cheaper. Before I made my leap of faith of using Vic oil filters I had the opportunity to talk with the Phillippine importer of VIC products. VIC oil filters are designed to withstand a 10k km oil change. This spec together with the use of Unioil 50 ppm sulfur diesel (lesser combustion byproducts that contaminates the oil resulting to extended oil drains) made me confident of the 10k km oil change. My oil spec (Petron Rev-X fully synthetic API-CJ4, SAE 5W-40) also helps. Its currently the cheapest high-spec fully synthetic oil sa Pinas. (Kindly correct me if mali ako sa last statement na ito as matutuwa ako if meron pang mas cheaper sa oil dito). :-)
March 27th, 2013 07:03 PM #5
March 27th, 2013 07:03 PM #6
- Jun 2016
- 2
June 30th, 2016 05:40 PM #7Mga kapuso. Paki advise nman po kung anong model ng vic at bosch oil filter ang mag fit sa aking granny adventure 4g63a gas engine. At yun po bang air filter ng montero ay pwede sa adventure. Kung hindi nmam po alin ang ka size nya sa mga mitsubishi vehicles. Salamat po ng marami.
April 30th, 2018 09:23 PM #8
March 27th, 2013 07:13 PM #9
March 27th, 2013 09:51 PM #10
I agree sayo RY.
*roy
Singit lang po, kelan pa naging manufacturer ang mitsubishi ng mga atf, alam naman natin na pinaltan lng un sticker name ng mitsu sp3 atf. Nyah!
Lahat ng car manufacturers yan ang gimik para kumita . .sabihinsa atin na di pwede un ibang brand at un kanila lang. Ganun paniniwala nun dekada sitenta, iba na ngayon panahon ni yap-kris at chiz-heart. Hehe
Tesla Philippines
