Page 2 of 10 FirstFirst 123456 ... LastLast
Results 11 to 20 of 92
    Jan 2013
    Quote Originally Posted by Jtanism Rules View Post
    Sorry to burst your bubble Ammiel Barlis, I have been using VIC oil filters for 5years and it works fantantic, plus-it's practical.
    To most people who just rely on brand and not the performance itself, I must educate you that VIC is Japan made and I have tried
    comparing it's filter paper to Bosch, Motocraft, GM, Union and Purolator...VIC's filter paper is finer and thicker. If you want to know about the company that made VIC for your peace of mind, pls. check this out: - VIC Filter -
    Thanks!
    I know that VIC filters are made in japan. I never said it wasn't. Filtering efficiency is not measured by merely looking at filter media alone. We have a resident oil and filter expert here sir Dvldoc. You can read all about the tests done on lots of filters at remote bypass filtration thread here in tsikot. I have been using vic's before until i found thru research that you can get better protection for your engine using better filters which are lot better than vic. Just because it's made in japan does not mean it's the best, usually is but not always.
    Thanks!
    sir nasubukan napo ba ninyo i-cut open yung used Vic filters? TIA
    Feb 2013
    Sirs, please advice what is best engine oil, oil filter and atf fluid for gls se TIA
    Mar 2013
    Sir if you want OEM filters may mura akong nabilhan. yung kuha ko sa FM kong OIL Filter was only 900Php lang at yung Fuel Filter 1,600 Php. Hindi sya SP (Service Parts) na kulay pula yung kahon. share ko contact number nya 2544730 look for iris
    Meron pinagbilhan dati yung kamember ko sa tscp eh, bosch ata yun sa may recto. Mas mura at mas matibay kesa sa oem.
    Oct 2011
    Quote Originally Posted by beni23 View Post
    sa Benavides un sir exclusive distributor ng Bosch products.
    Mar 2012
    Quote Originally Posted by Ammiel Barlis View Post
    Dont use vic filters. Inferior ang filtering kahit original. Use Bosch om36 mas mura but equal if not better than oem filter. Pina ka best baldwin bd 28 o kaya fleetguard filter kaya lang walang supply ngayon sa binondo at caloocan
    May I please know specifically where in binondo or caloocan baldwin filters are available?
    Thanks.
    Jul 2011
    Quote Originally Posted by green eagle View Post
    Thanks.
    sa gandara/Sabino B. Padilla St. malapit sa Soler.
    Aug 2010
    ingat lang sa mga fake oil filters.
    Oct 2011
    Thanks.
    Volmax tapat ng YMCA ung swimmingpool dun in binondo....
Replacement Oil/Fuel/Air Filters for Strada/Montero Availability
