Page 285 of 493 FirstFirst ... 185235275281282283284285286287288289295335385 ... LastLast
Results 2,841 to 2,850 of 4928
    #2841
    I went to mitsubishi yesterday, and as usual unlimited drinks and all the pampering. I'm happy with the free check up, thanks to alleged SUA victim. After the change oil and everything, it flies like F18.
    #2842
    Noticed an unusual longer line at Diamond Motors Quezon Avenue of MS for maintenance... including one with Bias Network stickers.
    Repeat a twisted tale many times, the gullible public will believe it enough to be gospel truth.
    Interesting sticker by the MSCP group at the end...hehehe.
    #2843
    Quote Originally Posted by Jfox View Post
    Nice! When braking, make sure to use the left brake pedal. The brake pedal on the right is what causes SUA from what i heard.
    #2844
    Quote Originally Posted by Luap View Post
    [emoji1] regardless, my right hand is programmed for the handbrake.
    Jan 2003
    #2845
    Quote Originally Posted by elaz View Post
    BTW, I just called Mitsubishi Jabez for the free check-up grabe Jan 11 pa (1mo from now) kasi 3 units per day lang daw sila tapos tinanaong ko kung gaano katagal ang check up less than 2hrs lang.
    Saw in the news last night, pila sa mga Mitsubishi casas for the free check-up. I wonder what they are checking up when they don't know what & where the problem is coming from with the fact their claiming driver's error??? So what if they've check-up the vehicle then the next few days SUA happens, they blame the driver again?
    Also in the news last night, drivers are staying away from Monteros on the road to escape from possible accident. They heed my call.
    The other night we're at MOA Viking parking area. Pag tapat sa Montero naka park told my kids to stay away in front & at the back at baka umandar bigla yan. We all are:hysterical:
    Aug 2004
    #2846
    Thanks for the manual. Do you have a compete service manual?
    However not all of us are technically incline so this is why MMPC should explain this not just to us Montero drivers but even to the public to at least lessen their fear.
    Actually, going through all the known issues and complaints regarding the 4D56, I can see the outline of a case beginning:
    1. We know the inhibitor switch is faulty. Which means that inattentive drivers might not know they're in "Drive" instead of "Neutral"
    2. Throttle surge due to voltage spikes and clogged EGR or SCV are not unknown. In fact, there are complaints about surge in other markets, but it is still supposedly controllable by the brakes.
    3. An extended surge requires a more major malfunction, however, and possibly extra oil to burn... (oil leak in turbo?) which would have resulted in a bluish cloud rather than the black cloud in the White Monty video (there was some blue, but not all that much).
    4. And you would still have to explain why the brakes didn't work.
    5. And you would still have to explain why the brake lights didn't work for exactly one minute only.
    The first two, however, could provide clues as to the cases of the ladies on the highway, though I think mat entrapment or mechanical throttle sticking cannot (and should not) be ruled out there.
    Jul 2011
    #2847
    Advice ko lang sa mga naka Montero ngayon is to install a cctv sa pedals para in case na ma SUA ang unit nila captured ang scene. Lalo na sa mga na experience na na nag SUA ang unit nila na hindi naman bumangga dahil may chance na maulit ang SUA ng units nila.
    If mahuli lang sana sa cctv yan solve na ang case.
    Jul 2011
    Oct 2013
    #2849
    Ang easiest diy patch dyan, lagyan voltage clamp yung signal wire papunta sa throttle body voltage level same sa peak ng signal kapag engaged ang compressor. Clamp will be deactivated when you press the accelerator.
    Jan 2003
    #2850
    Quote Originally Posted by rapidfire_28 View Post
    How can this be a driver's error. It run's perpendicular to the road direction thus are they saying the driver is soo damn that he/she want this to happen ? If a driver's error, the most it can do is bump the body not hump on the car. The came case dun sa Iloilo, she was just parking on the garage but then rammed the wall into the sala. How many times had she parked that park into her garage and suddenly she would like to ram her sala. And MMPC would claim driver's error. No wonder this problem is cannot be resolve cause MMPC keep's blaming the driver and that's more than 97 cases already. Is what MMPC stating is that their Montero drivers are damn stupid to cause accidents?
Mitsubishi Montero Sudden Acceleration Accidents [MERGED]
