Results 51 to 60 of 2045
- May 2008
- 289
June 4th, 2009 10:36 AM #51aha!!! when i went to casa to install the stepboard with led, the technician noticed that the lock pin of some of stepboards were broken. the tchnician told me that the installer of the power locks and stereo may have caused them because it was installed locally. Now your door panels may have similar damge... winterpine kaya may gawa???? hmmmmm..... noenetheless, hello whoever they are, your technician should be trained or it will bomerang back.. freindly advice, those incharge of C5 casa units may have caused them.....peace man/.........
- Jan 2008
- 3
June 4th, 2009 09:21 PM #52thanks for the info. will talk to my SA sa citimotors sa makati about it. bad trip nga minsan ayaw mag engage ng alarm tapos lakas pa ng ulan, basa na ako ayaw pa rin kaya had to do lock it manually tapos gumana din yung auto alarm parang nang aasar pa. anyway thanks again.
June 4th, 2009 10:57 PM #53
Alarm remote not working??
this also happened to me. After winterpine installed the steering mounted audio controls. When i got home the alarm remote wasn't working( kelangan pa susi-an)
What i did was. I just removed the battery of the steering remote...tried the alarm remote..it worked...then put the battery back on the steering remote. and the alarm remote has been working fine since yesterday.
June 5th, 2009 12:06 AM #54
June 5th, 2009 07:00 AM #55
hmm sa akin baligtad naman... there are times na ayaw gumana nung steering wheel remote. i dunno kung battery or kung may problema sa remote mismo.
anyone knows kung saan nakakabili ng battery nun? i've tried several stores and so far wala sa mga tinanungan kong bilihan ng watch or cameras.
- May 2009
- 37
June 5th, 2009 08:29 AM #56Good day. I admire the MS better than the fort. However I come to know that the MS 4x2 whose engine is the 2.5 diesel. This is the same engine used in the L300 van only with turbo plus the CRDI system.. is that right ? so then its the same engine of the Space gear (Diesel) that came out 10 or more years ago. I understand that this particular engine is "ma-usok" since I own a space gear. Would it have the same effect to the MS maybe 3 years from now considering a new vehicle fitted with an old engine ??
June 5th, 2009 09:03 AM #57
No its not. The only thing similar is the displacement. The DiD is common rail don't compare it with old school diesels found in the L300...
June 5th, 2009 09:07 AM #58
- May 2009
- 37
June 5th, 2009 07:16 PM #60
