Page 154 of 270 FirstFirst ... 54104144150151152153154155156157158164204254 ... LastLast
Results 1,531 to 1,540 of 2693
    Mar 2004
    #1531
    Quote Originally Posted by eyn_9 View Post
    guys, whats your take on inflating nitrogen in our tires? if its benefits far outweigh the regular air/oxygen, what is the best way to do it?.. kelangan ba ideflate muna before kargahan? or partly oxygen partly nitrogen? if so, ano ratio? tia
    Posted via Tsikot Mobile App
    Nitrogen is useful if your usual daily drive is a couple of hours of highway driving.
    Jun 2014
    #1532
    double post sorry
    Last edited by heropopoxean; September 7th, 2014 at 10:03 AM. Reason: double post sorry
    Jun 2014
    #1533
    Quote Originally Posted by vickoy1228 View Post
    here's my version of the grill, just bought the green plastic one and sprayed silver paint....i attached it using plastic cable ties and you can use as well Twist ties. Thanks to sir Bicol_ini for the idea.
    honey comb na sya
    Attachment 22876
    Ginawa ko rin to ...salamat sa idea. Me mga malilit ngang bato sa fmic at radiator ....this will help a lot.
    #1534
    if its free pwede. pang alis guni guni lang yan nitrogen sa tires, bakit ko nasabi, well, my wheels (305 30 26 on FM) then were inflated with nitro, then after a while na-flat yung isa, just inflated it with ordinary compressor. tried comparing the temp and tire pressure , thru real time monitoring(tpms), started from bulacan going batangas, all the 4 tires started at 35psi, upon reaching batangas, nitro registered 38psi, while the ordinary one was 39psi. kaya para sakin, kung free, larga pero kung sasadyain mo pa tapos magbabayad ka pa, no thanks
    Aug 2005
    #1535
    It all boils down to proper inflation, regular monitoring and checking and regular rotation of tires including that of the spare. Yung innova ko nabenta na lang after serving me for 7 years. All stock. Wala naman ako naging problem sa tires using ordinary compressed air ( I own one vespa 1hp compressor). Up to now gamit ko pa rin kay teroy eh.
    Aug 2005
    #1536
    Pero bossing zix, on the 2nd thought, kung maganda and ***y may-ari ng shop at laging nandon, ok din dayuhin kahit may bayad yung nitro 'di ba? He he. Joke lang mga kakosa.
    #1537
    Thanks po sa mga responses, very helpful for me to think more of.. May mga ngsasabi din kasi na hindi daw ganun katagtag kapag nitro. Madalas kasi na magaan lang ang sakay namin, at wala pa masyado gamit kaya madalas na din nahihilo baby ko to the point na nasusuka sya (sorry for the word), unlike nung sedan pa gamit.. Kung mas ok yung takbo, might as well try ko kahit may bayad. Pwede ko naman ibalik sa compressed air kung wala pagbabago.. Btw, GLX lang po kaya manual checking ako.. Again tia..
    Mar 2004
    #1538
    ^^^ When the tire heats up, pressure builds up hence the harsher ride. Nitrogen does not heat as fast as oxygen but you will notice this mostly if you drive for many hours on the highway enough to heat up the tires +4 PSI from normal pressure.
    Sep 2014
    #1539
    [QUOTE=zix888;2392693]another 2011 gtv just finished registration, egr blanked!
    Hi I'm newbie here. I'll be getting my new 2014 Montero Sport soon. I would like to ask sir kung kailangan na bang magpa blank ng EGR agad.
    Hindi po ba mavovoid and warranty ko. Salamat sir.
    Feb 2014
    #1540
    [QUOTE=truck4x4;2397839]
    Quote Originally Posted by zix888 View Post
    Yes sir. Have the EGR blanked agad. Ask master zix. He blanked mine. Warranty will not be voided.
    Afaik, casa has no business checking this mod during PMS. They will only check that yata kapag scheduled na yung EGR cleaning mo then they will find out na there is nothing to clean kasi nagpablank ka na way back.
2014 mitsubishi montero
