Results 741 to 750 of 2693
April 22nd, 2014 10:50 AM #741
Congrats, I can only give my feedback sa plate, got mine last December, followup lang ako sa Liason officer ng dealer where i got my Monty, I was informed last March i have a plate number assignment na, to follow na daw yun plate, then come April, i already got the plaste ( without the sticker), as usual to follow daw......
April 22nd, 2014 10:53 AM #742
April 22nd, 2014 10:56 AM #743
No problem Sir, i opted not to install Turbo timer, from the feedbacks from masters here, before i park i drive on low rpm ( 5 to 10 minutes), wala ng hataw. they say enough na yun for cool down.
Instead, i decided to install other mods like EGR blanking, cabin filter at OCC......
April 22nd, 2014 11:27 AM #744
You can check Perts Interionizer too. I hear positive feedbacks from monty owners who have their seats upholstered/customized there.
- Mar 2014
- 147
April 22nd, 2014 11:56 AM #745sensya na po newbie.para san po b ung turbo timer?saka may nakapag painstall nb sa gls-v ng TPMS and TV tuner and headrest monitor?how much?TIA
April 22nd, 2014 12:14 PM #746
A turbo timer is a device designed to keep an automotive engine running for a pre-specified period in order to automatically execute the cool-down period required to prevent premature turbo wear and failure. After a period of driving when a turbocharger has been working hard, it is important to let the engine run at idle speed for a period, allowing the compressor assembly to cool from the lower gas temperatures in both the exhaust and intake tracts. At the same time the lubricating oil from the engine is able to circulate properly so the turbine won't burn the lubricating oil that would otherwise be trapped within the charger with the turbine rotating at high speed. With regard to modern automotive turbochargers, the need for a turbo timer can be eliminated by simply ensuring the car does not produce any 'boost' (during driving) for several minutes prior to the ignition being shut off. Most turbo timers are based on digital electronics.
Turbo timers can usually be disabled by an external switch, this is normally done using the handbrake switch, or using an automatic one.
Turbo timer - Wikipedia, the free encyclopedia
April 22nd, 2014 01:44 PM #747
- Mar 2014
- 4
April 22nd, 2014 01:46 PM #748guys pati ba pagpalit ng tail light bulb sa casa pa? pundido agad yung sa right side tinawag ko sabi don daw papalitan may instructions naman sa manual.
Tsikot Member Rank 1
- Jul 2009
- 4,090
April 22nd, 2014 02:15 PM #749
April 22nd, 2014 02:41 PM #750
Hindi lang baka icharge ka ng doble sa presyo ng bombilya, pati pa labor!
Dalawang screw lang yan sir, bili na lang kayo pamalit tapos kayo na magkabit.
Kung medyo ayaw nyo, dalhin nyo sa autoshop na may binebenta na bombilya tapos pakabit nyo na rin.
Sent from my Nokia5110i using Tsikot Forums
Tesla Philippines
