Page 157 of 276 FirstFirst ... 57107147153154155156157158159160161167207257 ... LastLast
Results 1,561 to 1,570 of 5876
    Quote Originally Posted by youngrider View Post
    Is the paint of white Mirage, metallic white or pearl while, I noticed that you can see glitters when you look at it closely, it is actually not the plain immaculate white as my SA described. The Specs said it is savanna white but the predelivery specs of Mirage is unreliable, like the absence of remote trunk opener and keyhole barrel light. The underside is also practically littered with plastic coverings, large gaps and openings where dirts and water can easily enter or they may break if hit with stones as you pass graveled roads.
    Afraik the absence of remote trunk opener is normal for hatch back kasi sa hb nakarelay na sa power door lock the hatch door is consider 5th door kaya ipapa power door lock mo iyan at ing key hole barel light wala talaga iyon even thailand and japan version because the higher variant push button start na iyon may iluminated na pero since low end variant ingnition key traditional with out lamp iluminated.
    Jan 2010
    with 727 on the odometer the mirage wont start anymore
    Omg. What happen?? M/t ba or A/t sir?? Of A/t check if nakalagay sa P or N yung stick. Ako din kasi nabiktima sa previous A/t na ginagit ko.
    Dec 2012
    Unti-unti nang naglalabasan ang mga defects ng Mirage. Masamang senyales. Sana walang mga ganito ang makukuha kong unit. (Fingers crossed)
    Dec 2012
    Quote Originally Posted by blitzboy420 View Post
    Same here.. anu kaya nangyari?? however the posts here are very useful.. pag ka dating ng unit, check agad ung back seat..hehe
    Aug 2012
    Ba't mo naman sinisisi tita mo sa di pag-start ng auto mo. :-* At ba't mo naman naisip na sasakay siya sa kotse mo para lang takutin ka. =B)
    Ecclesiastes 9:5, 6
    For the living are conscious that they will die; but as for the dead, they are conscious of nothing at all, neither do they anymore have wages, because the remembrance of them has been forgotten. Also, their love and their hate and their jealousy have already perished, and they have no portion anymore to time indefinite in anything that has to be done under the sun.
    OK, para di OT, kung may problema unit mo at intermittent, sigurado babalik 'yan.
    Sent from my GT-N7000 using Tapatalk 2
    Dec 2009
    ^for the record im not blaming her, lighten up dude
    im still observing the car & will share whatever findings i get capish
    Jan 2011
    mirage owner kumusta po FC nyo? sa city at highway?
    Apr 2012
    Ano ba talaga principle ng START STOP sa Mirage natin?
    As per what i understand START STOP should be like this right:
    The new Volkswagen Jetta Stop/Start system - YouTube
    Ang lumalabas PUSH to START/STOP lang naman si MIRAGE.
    Can anyone clarify??? Bka meron lang ako na miss?
    Quote Originally Posted by nrthstr View Post
    what i saw on the clip parang same lang din kay mirage. Need to press the brake pedal pa din kung mag stop. Then kung ayaw mong mangawit paa mo kaka diin dun sa brake pedal need mo i shift yung stick to N or yung hand brake then release the brake pedal naka full stop kana nun. Yung start/stop button kasi pang start at pang off ng engine yun.. Can't imagine lang kapag naka red light then press mo yung start/stop button..
    Push button ignition on/off lang yong Mirage natin. Only for the sole purpose of not inserting the key into a keyhole then turning it clockwise to start the engine and turning it counterclockwise to turn off the engine. That's all. Convenience lang because no need to get the key out of your pocket or bag. Same is true for locking and unlocking the doors - no need to insert the key in the keyhole.
    We do not have the engine start/top system for fuel economy wherein the engine completely amd AUTOMATICALLY turns off (as in zero RPM) when at full stop (red traffic lights, talking to an MMDA officer, buying cigerette, etc.) then the engine turns back on AUTOMATICALLY when you remove your foot from the brake pedal.
2013 Mitsubishi Mirage
