Page 673 of 689 FirstFirst ... 573623663669670671672673674675676677683 ... LastLast
Results 6,721 to 6,730 of 6890
    Jun 2018
    #6721
    the schedule should be in the howner's manual, po.
    the only harm in replacing it earlier, is to the pocket.
    some argue that, because of our horrendous traffic, the better gauge is the hours of running and not the km run.
    Tnx for the advise po ...
    #6722
    [QUOTETttyyyyy
    #6723
    Quote Originally Posted by zix888 View Post
    Try removing the mass air flow (MAF) connector, tapos gamitin mo lang siya na unplugged. Balitaan mo kami. Take note , mag CEL yan, hayaan mo lang.
    Bro zix, remove ko na MAF sensor connector, nag CEL sya, lumakas ang hatak "D" drive & manual mode even incline, swabe takbo ng engine then before ko connect ang MAF sensor connector, nilinis ko MAF sensor using MAF sensor cleaner, result same tulad ng dati hirap umarangkada pag incline moving slowly pag naka bwelo saka bibilis ang takbo, note wala na syang CEL
    Dec 2018
    #6724
    sir zix, inbox full po. please check
    thanks
    #6725
    Quote Originally Posted by rosslei View Post
    thanks
    Cleared na, thanks
    #6726
    Quote Originally Posted by spiderjon96 View Post
    Palitan mo lang ang MAF sensor. Ok na yan. Or if ok sayo na may CEL, tanggalin mo na lang ang plug, ok lang yan
    #6727
    Ok bro zix, thanks
    #6728
    Quote Originally Posted by jakz View Post
    Thank you sir. By the way saan ko makikita itong 2 sockets?
    Sent from my CLT-L29 using Tapatalk
    You can see this module w/ 2 sockets, side-to-side with the antenna
    Unplug them
    #6729
    Thank you sir Zix for the detailed illustration how to unplug the 2 sockets of the TPMS.
    Jun 2009
    #6730
    Quote Originally Posted by Olsjam View Post
    Musta mga paps.. Happy new year!
    Ok lng ba sa 80k km odo na magpapalit ng timing belt set? Tnx.. Gtv 2012 here..
    masakit sa bulsa pero better to be safe than sorry. remember naka monty ka mahal ang ride natin so be ready sa sakit ng bulsa
    kay sir zix malaking mura oem pa
2012 Montero Sport Owners
