Page 110 of 689 FirstFirst ... 1060100106107108109110111112113114120160210 ... LastLast
Results 1,091 to 1,100 of 6890
    Jan 2011
    #1091
    tsikoteers, for everyone's information na din. Seaoil is now back to Euro3 from Euro5. Pero actually sabi nila is Euro3 talaga ang Biodiesel nila but there are times na 4 and 5 din dependent on the market price fluctuations. Pero right now, hindi nila kaya to offer Euro5 dahil sa taas ng price ngayon...Kaya ako back to Unioil which is Euro4 ever since, naka post nga ngayon sa pumps nila 50ppm...
    #1092
    Quote Originally Posted by zix888 View Post
    Yung mga high-powered 4d56 na monty KH4....... po ang model no., designed po for euro iv. Total is low sulphur din, meaning mas mataas sa euro II . i have been using seaoil since june2011. Pero siyempre iba pa din yung sinasabing malinis na station, meron lang din ako suki na station na pinagpapakargahan, tested ko na since 2011 , ala naman naging problema.
    thanks for the info sir.
    Feb 2012
    #1093
    Sirs so what diesel can you recommend the most on our montero?
    Sorry a newbie on diesel engine here
    Thanks!
    Sep 2004
    #1094
    Well sa company namin na mga naka monty, they never went back to their previous stations after topping up at seaoil. Actually most of us nga eh na-give up yung mga rebates sa mga suking gas company kasi sa seaoil wala kami nakukuha rebate, sobra liit compared sa dati. But then kasi kita agad yung difference, sa tail pipe/tip palang and sa odor , malaki na and improvement. Try mo lang, yung models kasi ng monty natin built for euro IV talaga, so dun pa lang advantange na agad kung euro IV and up ang ikakarga mo
    Target ko talaga yung Seaoil malapit sa amin (wala pa kasing Unioil or Eastern Petroleum). Kapag nagsawa na yung biyenan ko at ipinamana na sa akin yung MS, dun agad ako magpapakarga.
    Jul 2011
    #1095
    Quote Originally Posted by matty View Post
    Really? Saang mitsu yan sir? I have been using shell vpower, once lang ako nag turbo diesel. mas mahal kasi. if there is any truth to that e di mas ok nga. mas mura pa yung ordinary diesel compared to the premium ones.
    can someone clarify this? first diesel car ko yung monty. kala ko mas ok yung premium diesels like vpower and turbo diesel. hirap kasi maghanap ng seaoil na station kung hindi dun na ako as advised by some of the experts here. medyo naguguluhan na tuloy ako
    The statement about what diesel to use came from the WARRANTY guy not the SA at diamond motors quezon ave.
    Pag under warranty kasi ang unit the warranty guy (thats what they call him) is the one who inspects the problem and reports to the main plant of MMPC.
    So basically ang statement niya (coming from the main plant of MMPC) is that i should not use V power and petron TD, he said use PETRON DMAX and only from one station if possible.
    Update on my MS. Roadtest with CASA this morning - NO MORE JERKING, i asked them what they did, they said;
    1.) drained and cleaned my fuel tank then filled with petron dmax
    2.) cleaned fuel filter, fuel lines
    3.) replaced SCV ( 3rd time na!)
    4.) SIQL - something to do with ecu, computer
    They will release MS tomorrow, so i am crossing my fingers ok na lahat, and from now on will use petron dmax (will keep receipts) so that if it jerks again i will have proof.
    #1096
    Quote Originally Posted by tuazon7 View Post
    Good to hear na may ibang options na, aside from seaoil. Any update on total bro? Their pumps say low sulphur, pero wala nakalagay kung ilan ppm
    Jan 2012
    #1097
    about jerking problem.... kanina nagpunta ko sa freeway motor baliuag.... then pinaaus ko ung ms ko after that na check naman nung warranty malinis ung diesel (REGULAR DIESEL) but nung na check nila ung parang malapit sa egr ata un may bula daw sila na tingangal ito daw nagcacause ng black smoke and jerking.. then when i tried na hinataw ko ng hitanaw and tiningnan ko kung nagblblback smoke pa sa likod wala na.... and try at low rpm nawala ung jerking nya.. pero observahan k padin siya this following days. and sabi nung warranty dun wag daw vpower diesel and turbo diesel saka biodiesel ang ikarga kasi marami nag nagcocomplain sakanila ng MS about sa diesel na kinakarga they dont recomend ung mga diesel nayun..... regular lang daw dapat... may tinuro siya sakin kanina na strada nagpagawa malaki daw nasira sa makina... dahil vpower kinarga aun nakatenga dun ginagawa
    Feb 2010
    #1098
    Guys, The Non-VGT (Stripped down) Montero A/T and M/T will be available this coming April, price range is 1.2m-1.3m. for inquiries, just call or txt me. 0922-838-9641. thanks!
    Sep 2011
    #1099
    Sirs, do you really notice an improvement in terms of fuel economy while using unioil biodiesel 50ppm compared to Big 3 ordinary diesel? Upon test, mas mataas ang economy ko while using TechronD ng 1km/L compared to unioil diesel 50ppm.
    I tried this several times (fill to brim, use fuel until redlight lits, fill to brim). I am a unioil diesel user (wala ng iba) since august 2009until july 2011 and within this time frame, twice ako nagkaroon ng EGR error. I also fill up at my suking gas station here in Manila. Upon swithching to TechronD, dun ko agad nalaman na mas matipid siya compared to unioil. I'll be happy to read your opinions on this kasi from my experience, medyo iba. BTW, unioil diesel 50ppm started last march 2011, so I used and tested it for 4months.
    Im also sure na calibrated yung pumps ng suking unioil gas station and fuel is clean and in good condition kasi i know the dealer (if you know what i mean).
    Not sure though sa caltex. But remember, walang gas station ang gusto magbigay ng more than 1 liter for its price. Laging mas mababa ng 1000ml ang nilalabas ng fuel pump. (max error is 5ml per 1L. If sumobra, under grounds ng DOE yan. In other words, kapag bumili ka ng 1 Liter of fuel, dapat marereceive mo is 995ml and above. Kapag kumulang, lagot sa DOE ang station kapag nagkaroon ng rounds.)
    #1100
    Quote Originally Posted by Seeyah14 View Post
    Ang gulo din ng mga casa. Sa Mitsu Marilao, ang sabi sa akin hanggat maari Trubo XP or V-power ikarga ko. yung extra gastos kodaw sa quality diesel ay mako compensate naman sa savings sa maintenance ng engine. Ang engine ng mga MS ay from Thailand, and similarly also sold in Thailand, and if I am not mistaken diesel in Thailand are now Euro-4 and above compliant. And even if you google it, CRDI engines are modern engines design for new generation of diesel fuels. Confusing talaga, to me I will rely on experience, my monty runs well on V-power but terrible on Turbo Max.
2012 Montero Sport Owners
