Results 1,011 to 1,020 of 6890
- Sep 2009
- 5
March 18th, 2012 11:23 PM #1011Hi Sir,
Thank you for the input. Maybe 20"s would be best for me. Any noticeable change in the (km/L) after switching to 20"? When I upsized my Civic's 16" OEM rims to 18" I noticed an ave of 1 Km /L decrease in my readings after the change. I am guessing I can expect the same.
Tsikot Member Rank 1
- Jul 2009
- 4,090
March 19th, 2012 12:38 AM #1012
Hi Zix888,
Thank you for the very informative pictures and insights :-) . I'll probabaly stay with the 20"s with 30+ offset. The Dropstars DS03 or VCT Romano from Concept One looks right. I will just have to check the offset. By the way , the PCD of our Monty is 139.7 right? The VCT Romano is 139 exactly. Do you think it would still fit wheel hub/studs?[/QUOTE]
Yup its 6x139.7mm or 6x5.5" when buying abroad. Dont worry sir, when they say 139, its just a short cut for 139.7, same fit lang yan
March 19th, 2012 12:48 AM #1013
sir zix... totoo bang yung battery ng tpms ubos na.. tapos na yan? i know master kayo ng diy and galit kayo sa.. battery kaya ask ko nadin... 9 yrs napo kasi fm namin.. and sabi samin ng winterpine.. nasa 6 yrs lang buhay niyan... kaya iniisip ko.. masisira na amin anytime soon.. hehe
thank you doc otep... i think idelay ko muna headrest lcd ko.. ang totoo.. napakaselan ko sa sasakyan.. kaya pag may kinakabit na accesories minsan pinagaaralan ko nalang to do it my self.. primary purpose ko is hindi naman po yung tipid(minsan kasi natatakot din ako mali saksak.. sira lahat.. hehe hindi tipid yun) but rather.. dahil sa selan ko... minsan ayaw ko pabaklas sa technicians stuff ko sa sasakyan.. naiinis ako na minsan bara bara trabaho.. and once nadent nila plastic nabali nila... sorry nalang sasabihin nila... medyo naiinis kasi ako sa sobrang tornilyo na madalas ko napapansin sa trabaho nila and yun nga.. hindi nila iniingatan mga edges ng plastic.. napansin ko tusok nalang sila ng tusok ng flathead screw driver... sana takpan nila ng basahan para walang marks.. hehe
thank you very much sir sa sinabi niyo.. atleast alam ko na.. hanapin ko sa manual ang video out.. hehe to make sure meron yung h.u. ko.. thank you very much po for your reply.. it is very helpful.
- Jul 2009
- 4,090
March 19th, 2012 02:34 AM #1014
Swerte mo na sir na umabot ng ganyan katagal yan. Ang ic niyan after mafully dead battery, busted na, so i strongly suggest na bago tuluyan na maubusan ng battery eh palitan mo na. But take note na at all times dapat may supply siya, meaning, before ka magtanggal ng old battery, make sure na may naka parallel na new battery, kasi if not and mawalan ng supply yan, busted ic ka na. Madali lang naman, yung battery hanap ka lang ng ka size, hirap maghanap nung exact model eh
March 19th, 2012 10:44 AM #1015
March 19th, 2012 10:50 AM #1016
sir yung video playback mo lang from the disc, iPAD, iTouch and iPhone can be seen sa headrest monitors. video playback from the usb, limited so far sa ngayon sa main LCD. yun ibang screens like radio, gps and the like hindi sya kita sa headrest LCDs. You can do open the HU and get the LCD out directly though...
- Sep 2009
- 5
March 19th, 2012 11:26 AM #1017
- Jul 2009
- 4,090
March 19th, 2012 11:34 AM #1018
March 19th, 2012 01:49 PM #1019
thank you very much sir zix.. that is very very informative...
ang galing..
iniisip ko nga... noon.. hayaan ko masira... tapos pag nasira dudukutin ko nalang battery to have it replaced.. di ko alam ganun palang may pwede masira na ic.. hehe
i have a few questions lang po... :D para di magkamali sa procedure.. hehe
1) remove sensors from tires....?
ok... hehe dalhin ko nalang sa tire shop
2) pry sensor open
madali lang po ito sir? small screw driver?
3) replace battery
how do i do this po sir?
should i solder the new batteries parallel? then cut the old ones loose?
4) reinstall sensors..
any tips? :D
tama po procedure ko? hehe
pasensya na.. madami tanong.. just dont want to kill the ic
do you remember what model battery you replaced the original batteries with?
hehe
thank you very much po:D
sir tuazon...
yes.. dun nga po ako nalito hehe
hindi kasi sure yung... shop kung... ang makikita is movies only or anything na makita ko.. hehe anyways.. hindi ko nalang muna galawin.. unahin ko nalang po muna replacing ng battery ng tire sensors.. mukhangyun kasi pag nasira.. sayang.. hehe
- Oct 2008
- 47
March 20th, 2012 11:23 PM #1020Mga sirs, may nakapagpalit na ba ng K&N drop in filter sa inyo para sa monty 2012? anu part number ng filter kasi pag sini search ko sa k&n website ibang mga montero model ang lumalabas e. May nakita ako here in las pinas sa staging lanes in shell perpetual nasa 5.8k ang benta. Mahal ba yun? D kaya ma void warranty kung sakali palitan ko yung filter para na rin sana less maintenance in the long run.
And also i found in concorde sm southmall some mitsuba horns. Medyo pricey lang kasi japan made. Cheapest nila is nasa 3.2k. Sabi nung installer kabit lang daw walang splice sa wirings kasi tatanggalin yung oem horn tapos salpak lang bale magkakabit lang daw ng ground wiring sa body. 12 volts nga pala yung busina so i assume kahit walang relay ok na? Eto po yung model ng mitsuba nasa red box cya e. Wala lang po ako makita na pics sa net. MBW-2E11B
Thanks in advance
Tesla Philippines
