Page 94 of 501 FirstFirst ... 4484909192939495969798104144194 ... LastLast
Results 931 to 940 of 5006
    Jul 2004
    #931
    the jury is still out on the "sudden acceleration" issue for me
    i would rather wait for the full, factual and objective report on the monty M/T incident
    until then, IMHO, is all appears to be driver error
    otherwise, if this was a widespread occurence, then more will be reported not just here in the philippines but also in other countries (australia, south africa, ukraine, south america etc) on this alleged manufacturing defect considering that the engine and transmission are all similar AND i doubt if mitsubishi can keep this under wraps that long (3 years or so)
    until then, i am fully enjoying my monty, wooohoooo!!!!!!!!!!!
    May 2009
    #932
    sir rmsoriano and sir ARB, thanks po sa clarification! more power!
    #933
    Quote Originally Posted by ARB View Post
    Mga sirs with regards sa turbo timer, it costs just 2,500 more or less (miccon, volution, amata, etc.) and it really serves a function. Compare this to putting mga add ons sa MS na doesnt serve a purpose but just to add bling to the car, I think installing a timer is a wiser move.
    If you have the budget, it is indeed a wise and safe move. It will make sure your turbo won't fail you for the length of its service.
    Aug 2007
    #934
    Quote Originally Posted by jaejae View Post
    wala po bang safety issue ang turbo timer? di po ba pag switchback mo ng key to off position, di po mag stop yung engine but rather run for a pre set time then stops automatically? what if po in an emergency situation that you have to stop your engine instantly?
    just push the single button on the turbo timer, it will instantly shut down
    May 2011
    #935
    Quote Originally Posted by venom810 View Post
    does 2011 Montero Sport GLS-V 2.5 AT comes standard with reverse sensor and third brake light? thanks for the reply.
    monty sport gls-v comes with a reverse sensor. the third brake light is mounted in the upper rear window.
    May 2011
    #936
    +1 ako kay bikoy888
    you can override the turbo timer, just turn it off.
    Apr 2011
    #937
    Hindi ko nacehck sa MS kung may clips sa flooring para lagyan ng matting na may holes? Sa Pajero meron kaya yung OEM matting hinding-hindi magslide at wala din deep groove na puwede mag-stuck yung metal bracket of the gas/brake pedals.
    My gls-v has. Or if this is not standard, maybe the clips came with the matting, not really sure as i did not really noticed it also until the matting that I bought from the parts has been installed in my unit/
    Apr 2011
    #938
    Quote Originally Posted by ggmms0411 View Post
    check this site:
    http://www.mitsubishi-motors.com.ph/...ccessories.pdf
    the floor matting is available here in the philippines, check your dealer.
    i check the flooring at the driver side and found two hook, maybe this is the area where we can attached the matting. i try later two have some picture of the hook.
    This matting is what i have on my Monty about a month after i purchased my unit. They have been offering me this from the day that my loan was approved by the bank. This is from the parts department and not from winterpine.
    May 2004
    #939
    for me driver error din,
    lalo na if this is a M/T, driver should always start the car with handbrakes ON and in Neutral while stepping on the clutch pedal when starting...
    kahit naka apak ka sa gas or mag wild rev engine nyan or topakin ECU or hindi gumana brakes pero hindi pwede mag move ang car..
    ofcourse there is no way the car mag in gear ang M/T by itself
    I am very satisfied with my Montero too
    Apr 2011
    #940
    Quote Originally Posted by don View Post
    It could be that the two drivers involved probably has the same old school habit being mentioned here when one is used to driving carburetor type of vehicles. It may also be that there really are problems with their units but for the 2011 model, i am sure these has already been addressed with assuming there were any concerns to begin with/
2011 Mitsubishi Montero Sport [continued]
