Page 48 of 501 FirstFirst ... 384445464748495051525898148 ... LastLast
Results 471 to 480 of 5006
    Apr 2011
    #471
    Quote Originally Posted by mckoyboni View Post
    Same style but di pasok yan sa bagong Montero, iba ang dimensions
    Apr 2011
    #472
    BTW, talked to my Mitsubishi accessories agent, darating daw next week yung OEM LED daytime running lights for the Montero. Will check it out sa UMC UN Avenue. Also, for GLS-V owners who are interested in acquiring the Tire Pressure Monitoring System tulad ng nasa GTV, I asked the CASA and they quoted me 15K for the installation.
    May 2011
    #473
    Quote Originally Posted by bjreyesmd View Post
    The camera replaced the plate lamps, and yes, it is bolted on. You have to remove the sidings of the whole trunk door in order for you to install it. Sa Union Motors UN Avenue, 6K ito. have mine installed by them.
    ok, will check them out soon. Thanks!
    Also, regarding your post on the Tire Pressure Monitoring System, Winterpine also quoted me 15k for that. So might as well have it all done sa CASA!
    #474
    Quote Originally Posted by eccm View Post
    I recently upgraded my gtv's audio system at tsikot.com shop in taguig, wth the help of jedi and his installer jon. Iam satisfied with the outcome at a very reasonable price. thanks dude...
    * eccm,
    could you care to share what components you added, the brands, and the cost? (pwede rin PM if you want) Thanks!
    Jul 2004
    #475
    i prefer this type of rear view camera to the one where you have to bore a hole in the bumper
    how is the resolution at night? is it clear ba?
    May 2011
    #476
    Quote Originally Posted by NY2006 View Post
    * eccm,
    Yes, please share! Montero stock speakers are really bad! Thanks!
    Feb 2011
    #477
    Here is mine:
    1. HU - stock need to retain the MID, problem is this unit has limited tuning capabilities
    2. External Processor - Alpine PXE-H650 to address the tuning needs for the system, I had to purchase an external processor. Bought this from Amazon for US$350. There are others that are available such as JL Cleansweep, Rockford Fostgate 360 locally they retail for 20K+++
    3. Front Speakers, I replaced mine with Focal Access 2-way seps retails for 10K
    4. Rear fills - Pioneer 2-way coaxials - 1.9K
    5. Amp - Powerbass ASA 600.4x -9.9K
    6. Wirings and interconnects - 5K
    7. Sub RE RE10" sub + 1 cu. ft. enclosure sub 4.5k + box 2.5k
    8. 1 pair 7" headrest monitors - 7.5k
    9. Door deadening STP brand 1.2k per sheet 1.5 sheets per door/6 sheets total 7.2k
    This should total to about 63K. If you are not too picky about sound quality then you can forgo the sound processor
    Aug 2010
    #478
    Focal Access 30A1 should retail 10k (9800php I believe) but you can get one at 8,500php easily. I also think you overspent for the StandartPlast/STP deadening. Although they're one of the best in the market, they also have the "premium" pricing attached to it. Stinger Roadkill or OEM Acoustimats would be better since these would cost lower and trade-off is minimal (for the Stinger). But overall, nice yan pare!
    Feb 2011
    #479
    Quote Originally Posted by jhnkvn View Post
    Sorry forgot to add that I deadened all 4 doors and that is the reason why it totalled 7.2k. If on a budget, you can just deaden the front doors.
    Aug 2010
    #480
    Quote Originally Posted by rafmac View Post
    For 4 doors, mura na yun STP. Can I ask for the installer and the STP lineup they installed? I installed 6 layers of STP Silver (2 layers for each of the front door and 2 layers at the trunk lining) and it cost me 13k. Personally, it was a bit expensive but there are improvements over Stinger Roadkills and Dynamat Extreme. Kudos to STP for garnering 36% market share in sound deadening in EMMA Philippines.
2011 Mitsubishi Montero Sport [continued]
