Page 364 of 501 FirstFirst ... 264314354360361362363364365366367368374414464 ... LastLast
Results 3,631 to 3,640 of 5006
    Jun 2012
    #3631
    wow. very informative. thanks for sharing. talino talaga ng pinoy. sana sa kabutihan ginagawa
    Apr 2008
    #3632
    Quote Originally Posted by tuazon7 View Post
    Anybody knows what is the maximum USB size our HU can handle? Tried using my 320Gb drive but was not recognized.
    Try to confirm if your USB is formatted to FAT32... If not then try to format it first then try again.
    Sep 2012
    #3633
    Quote Originally Posted by babynos01 View Post
    Regarding headlight intensity, kung kaunti lang naman yung pagliwanag, wala naman problem yan.
    It only means na yung voltage generated ng alternator tumaas ng kaunti kasi lalong bumilis yung pagikot.
    Ang masama, kapag hindi naging stable yung generated voltage.
    i.e, as your rpm increases gradually, headlight intensity also increases gradually.
    Pero kung hindi naman yan ang scenario, ok lang yan.
    Regarding naman sa pag jerk along an incline, is this kapag nag downshift siya?
    I had mine before, pero biglang nawala. nilinis ng casa yung egr pati intake manifold kasi nag ka cel din ako nun.
    Now wala na yung jerk specially new na atf ko.
    thanks. actually i'm not to worried about the changing headlight intensity compared to the jerking on incline. yes, the tranny down shifts from 2nd to 1st. to eliminate the jerking, i usually go to manual and down shift to 1st myself.
    will try your suggestions to have atf change, egr and intake manifold cleaning. thank you sir.
    Feb 2007
    #3634
    Quote Originally Posted by SeismicMan View Post
    Max size so far that it can read is 16GB. Even formatted to FAT32, it wont read the 320GB HDD. What i did is create partitions of 16GB for each type of media (music, movies, etc) on my 60GB HDD. This idea also came from a montyner. ;)
    Aug 2003
    #3635
    This is my thread specifically on my problem on the fluctuating voltage.
    http://tsikot.com/forums/electricals...montero-89963/
    Ang masama dito, sabi ng mitsubishi, normal lang yan, kasi according to their computer, walang problema. Pero ang lumabas sa testing ko, ang bilis ng voltage drop niya, from 13.8 to 12.5 in just 5 minutes or so. What's worse is that when we went around the casa's motorpool and looked for 2009 and 2010 models, we found two, and both units had the same voltage drop as mine. This was the basis for mitsu casa to say, ganun talaga siya. Sabi ko, hindi lang alam ng may ari nila na may voltage drop sila. Kasi yung isang kaibigan ko na may 2010 montero like mine, hindi nag voltage drop, while I have two friends with the GTV, wala silang voltage drop. Plus another 2011 GLX that the owner I only met at the outside accessory store, wala siyang voltage drop. Yung Strada ko, with the same engine, wala ring voltage drop. I have another car, a local Sportage, wala ring voltage drop.
    Aug 2003
    #3636
    Quote Originally Posted by ctiongson View Post
    hi sir, I have exactly the same problems as you had with the lights and the sudden jerk going on an incline. I have the same 2010 4x2 model.mI tried to do a search from the threads but I'm not sure if others had these problems as well. May idea po ba ang mga Monty gurus about this? Anybody else having these issues?
    I also had the jerking problem checked. Ang sabi ng service manager, according to the computer, the there is no problem. Thus, the jerking is normal. Jerk.
    Sep 2011
    #3637
    *altec Sir since you already conducted tests, maaaring tama ka nga. At 12.5V, nadidischarge ba battery mo? Say, humihina na? Try ko imeasure voltage ng amin mamaya.
    *ctiongson *altec Yes, hindi din nadetect ng computer ng mitsu yung problem sa jerking. Nung nafeel ko before yun, takbo agad sa casa. Pero since wala nga reading sa computer, the only way to prove it to them is by letting them experience it. Nangyari rin sa akin yung rough shifting from 3rd to 2nd while running. Hindi din nadetect sa pc yun. Sinwerte nagkaroon ako ng CEL, so they replaced EGR (the 2nd time na magka CEL), clean intake manifold. After that, unti unti nawala jerking. Nagsimula yung problem namin sa jerking and rough shifting around 21K and nawala siya before kami magpa 25K PMS. Im now at 42K and swabe parin shifting.
    *ctiongson check mo muna level ng ATF mo sir. Baka sobra. According to one tsikoteer, sobra daw nailagay na ATF ng factory nung nagpadrain siya e. According sa SMV, it causes shifting problems.
    Sep 2011
    #3638
    Quote Originally Posted by altec View Post
    Sir nabasa ko sa first post mo na 650 lang idle rpm mo. Yung amin around 730 e.
    Check ko mamaya under the hood kung ano ba normal idle speed.
    Sep 2012
    #3639
    I've checked the service manual, and it states that idling speed should be 650 +/- 50 rpm. When I checked the metal plate stuck to the hood of the engine bay (lower left when the hood is open), it states 700 +/- 30 rpm. I checked the actual rpm on a cold start and it varies anywhere between 600 to 680 (this is based on an OBD scanner readings using Torque app for android). So it looks like the casa followed the service manual specs. Unfortunately, it looks like 600 rpm is too low for the charging system to be able to produce a stable voltage output. I think they should reset the idling speed to 700 rpm based on the specs on the metal plate.
    Aug 2003
    #3640
    looking at the dashboard, kada guhit sa rpm nasa 200rpm increments. yung needle ko nakapatong na sa 600rpm. i will talk to mitsu again to insist based on the hood plate stating 700rpm, although yung sabi nila na nasa specification ako it will only be correct based in the service manual and its really at the minimum. at 600rpm, nagdidischarge siya kada switch on ng load. ezxcept when you switch on the aircon compressor, tataas ang idling rpm. when that happens, steady ang voltage. this just means mababa ang 600rpm.
2011 Mitsubishi Montero Sport [continued]
