Page 285 of 501 FirstFirst ... 185235275281282283284285286287288289295335385 ... LastLast
Results 2,841 to 2,850 of 5006
    Jul 2004
    #2841
    Quote Originally Posted by zix888 View Post
    Goodbye battery!!! ( on my steering wheel audio remote )
    montero sport gtv 2011 - YouTube
    ito din ang gusto kong DIY
    #2842
    Pa suspense pa sir Zix ha!
    Share naman the DIY!
    Thanks..;)
    Sir madali lang yung diy nung sa battery, LM-317T and resistor to get a 3V output. Ang problema lang sir na nakikita ko for 2011s is yung kinuhanan ko ng supply ay galing sa harness nung cruise control ko. Kelangan palit pa kayo ng clockspring just to get power supply.
    Jan 2012
    #2843
    Quote Originally Posted by Edgar Ranara View Post
    gud evening sir ask ko lang sana kung bakit ayaw mag function ng remote control ko sa steering wheel para sa car stereo... bago po naman yong battery but still not working.. can you please help me on this matter.. many thanks po.. my montero sport is glxv 2011 model.. thanks
    hellow sir.. you need to reset the remote control steering para gumana siya ulit... try mo hold ung + and - na sign sa steering wheel den dapat naka off ung car.... then hold mo siya + - and negative den try mo paandarin ung engine then may maririnig ka na tunog na toot .. nagrestart na un.. then try mo kung gumagana na siya ulit. pag hindi pa.. restart m ulit until it works....
    Sep 2011
    #2844
    Sirs, goodmorning po.
    Ask ko lang, paano po inaadjust ang valve clearance ng Montero Sport?
    Conventional type ba siya na we need to open it up and tighten it using screws/wrench?
    Thanks.
    Feb 2007
    #2845
    Thinking of getting the 12V supply to the ignition.
    Found this cuircuit, will check kung pwede..
    #2846
    The problem bro, from the ignition going to the steering wheel , without the connection thru the clock spring, the wire will get twisted as you turn the wheel
    Feb 2007
    #2847
    There should be a power source on top of the clock spring, am thinking of the horn switch. Ito siguro pwede pero kailangan yung circuit is small enough to be hidden behind the cover..
    #2848
    Option mo lang bro is the airbag line, hindi ko kasi ginalaw yung line na yan baka mag srs warning eh. I already checked the horn, grounding lang lang siya, walang supply
    Apr 2011
    #2849
    Sir zix888 may cruise control ba 2011 gtv o pinakabitan nyo po? If yes, san po pwede magpapalit?
    #2850
    Quote Originally Posted by dohcvtec View Post
    Wala po cruise control yung 2011 gtv, diy ko lang. , bought the parts online. hindi pa kasi alam ng casa and winterpine how to install and make it work kaya no choice. Had to do some connections sa ecu to some connectors . yun yung critical sa diy ng cruise control
2011 Mitsubishi Montero Sport [continued]
