Page 273 of 501 FirstFirst ... 173223263269270271272273274275276277283323373 ... LastLast
Results 2,721 to 2,730 of 5006
    #2721
    Quote Originally Posted by tuazon7 View Post
    nice bro! anong klase yun seatbelt switch na inorder mo? and where you able na to open yun seatbelt mismo? check ko parang medyo mahirap buksan yun seatbelt lock without having scracthes...TIA.
    Bro itatabi ko na lang yung oem anchor lock, nagcheck ako mga spare parts ko and i found this, it came out from 2nd row seats of a fieldmaster(oem). It fits perfectly. A little mods lang, installation of switch and mounting. Mas madali buksan kaysa sa oem natin eh.
    #2722
    Sir zix paano po ba hanapin yung part numbers sa SMV?
    Sir sinubukan ko yung part no. Sa mitsuparts.com, not found, mukhang hindi yata part no. Yung makikita sa circuit diagram history(bottom) nung smv. Tried this seat belt switch MU801673, wala daw eh
    Feb 2007
    #2723
    Quote Originally Posted by zix888
    Yes sir, yun yata yung diagram reference number. The only part numbers i found so far are those for the special tools. ;)
    Parang there still some exe file that need to be installed para makuha yung part numbers.
    #2724
    Pwede din daw na ipabasa sa tech ng mitsu para makuha yung part No.
    Feb 2007
    #2725
    Quote Originally Posted by zix888 View Post
    I don't know if this can help..
    Auto Parts mitsubishi- parts directory
    This might be helpful if something can't be read. :-)
    http://translate.google.com/#
    Sep 2011
    #2726
    Sirs goodafternoon po, off topic lang.
    Bumili ako ng DRL, DIY ko po sana yung pagkabit. Gusto ko po sana, pag naka ON ang engine, on din siya. If OFF ang engine, off din siya. Saan ko po ba itatap yung device para ganon ang operation niya? hindi ko na lalagyan ng switch para less hassle.
    Thank you po.
    #2727
    better nga bro kung integrated na lang sa opened-door warning buzzer. pa share naman bro nung part number ng seatbelt switch. TIA.
    Plan B bro, sa reverse warning buzzer na lang, hindi pwede sa opened-door buzzer, nag turn on yung warning lamp ng opened-door tsaka since it is connected din to the speed sensor, kelangan pa magmove bago mag alarm
    #2728
    Negative Din sa reverse buzzer, 5 volts lang yung kelangan supply ng buzzer, mas madali kung separate na lang na buzzer. Okay na yung anchor switch, mounting na lang
    Jul 2004
    #2729
    kailangan talagang makita ang lahat nang na DIY nyo, i.e. steering wheel remote backlights, security light, side mirror led arrow lights, seatbelt indicator lights, atbp
    galing!
    Dec 2009
    #2730
    Sir zix pashare naman kung paano gagawin yung seatbelt lights at buzzer pati na rin yung parts na kailangan. Thanks!
2011 Mitsubishi Montero Sport [continued]
