Page 398 of 501 FirstFirst ... 298348388394395396397398399400401402408448498 ... LastLast
Results 3,971 to 3,980 of 5006
    #3971
    larry123 gave the go signal for this pic to be posted
    #3972
    Quote Originally Posted by Larry123 View Post
    Ung wife ko ang nagdala ng car sa service center d nya iniwan sabi ko sa kanya tingnan kung anong ginagawa sa car. actually that time nasa abroad pa ako. nung tinanong ko ung mga mekaniko sa service center kung saan namin dinala ung monty after the incident d daw nila ginagalaw ang differential that what they say sa 20k km pa. Tanong ko sa kanila kasama ba sa checklist ng 5k PMS ang differential d nila masagot ng diretso. As helecopter mechanic medyo nakakaintindi ako sa pagdating sa PMS kasi mas delikado kung may mangyayari sa aircraft kaya may dulplicate inspection kami sa vital parts kaya d ko talaga pinapalampas un. Sabi pa nga nila sa wife ko 10k km na palitan ang engine oil pero sabi ko "NO" ipachange oil mo kahit synthenic yan nilagay sa 1k PMS.
    Sir during your pre-trip inspection, did you check the ATF level in the engine bay?
    And after the accident is there a sign in the differential drain plug that it was previously opened or any dent at the bottom part of the differential housing?
    Jun 2013
    #3973
    SIr Glenn, Did ou mean The Automatic Transmission Fluid Level, I checked all the fluid levels at vital parts as part pre-trip visual inspection and 360 degrees visual inspection sa car. ung mechanic na ang nag open ng drain plug, as far as I remember walang problema ang differential housing any dents or unusual marks.
    Aug 2003
    #3974
    30k kms ang casa interval for changing Differential fluid. So during your 5k PMS sir I am 100% sure that they did not check the fluid level. Kasi visual inspection lang ang gagawin nila diyan (kung ginawa man nila). That is why I am emphasizing that kung talagang the cause is the lack of differential fluid, the one who should have inspected it during the Pre-Delivery Inspection should be the one held liable..
    Take a look at this diagram of the Rear Differential Assembly..
    ESSI24 - A/T..CARRIER ASSY,DIFF - REAR AXLE - REAR AXLE DIFFERENTIAL - PAJERO/MONTERO SPORT(EUR/MMTH) - ????? ??????????? - ?????? - Mitsubishi - ??????? - ???????????? ???????? - ?????????? - ????????
    I don't know what part failed based on the actual picture shown.. I am guessing it may be the diff drive bearings due to the lack of lubrication?
    #3975
    Thanks for the info sir Larry, Nangyari na kasi yan sa isang pick-up namin dito sa site, naubusan ng differential fluid, sumabog din. Sumabit kasi yung rear differential sa bato while crossing a river, nasira yung pinion seal, nag leak. Parehas yung itsura ng damage sa picture na post ni sir Zix, although yung sa case namin nagka butas yung differential housing nung sumabog.
    Ang extreme cause na naisip ko dyan ay ginalaw ng mekaniko ng casa sa 5k PMS ninyo yung drain plug, Kung kulang na kasi yang langis from the factory hindi na aabutin ng 5k km yang differential ninyo at maririning ninyo yung whinning sound. Kung may defective oil seal naman, dapat may mapansin kang leak o oil sa garahe mo.
    #3976
    Quote Originally Posted by ek2jayvee View Post
    If they check it , they probably open the wrong plug.
    Jun 2013
    #3977
    Walang leak talaga kasi nag 360 degrees visual inspection ako kasi malayo ang pupuntahan namin vital parts and differential eh. Walang tama ang differential ung filler cap kung saan nilalagyan ng oil nagkaleak na kasi ang tendency ng metal pag masyadong mainit nagexpand na. wala un na sinilip ko eh.
    #3978
    in that case, sa pre-delivery inspection nagkaroon ng diprensya, umpisa pa lang wala ng lagis, bibigay talaga yan
    #3979
    #3980
    Quote Originally Posted by zix888 View Post
    Sir Zix is it possible for half filled or not oiled differential to last 5k kms before it will explode?
2011 Mitsubishi Montero Sport [continued]
