Results 21 to 30 of 2054
January 26th, 2011 10:16 AM #1
Sooner or later you will be driving your monty..be a proud owner and enjoy the ride.
cheers
- Mar 2010
- 171
January 26th, 2011 06:57 AM #2
January 26th, 2011 09:50 AM #3
- Sep 2009
- 22
January 26th, 2011 11:21 AM #4
- Jan 2011
- 49
January 26th, 2011 02:00 PM #5mga sirs... eto na final spec ng 2011 montero se:
variant will be called montero sport GT-V 4WD AT
Engine: 4D56 2.5 turbocharged and intercooled dsl
Max Power: 178HP/4000rpm
Max Torque:350Nm/1800 - 3500rpm
Turbocharger: Variable Geometry Turbo (developed by IHI)
key spec changes for the Montero GT-V:
- 4speed INVECS II AT to 5speed INVECS II AT
- new front grille w/ GTV emblem (Honeycomb)
- paddle shifters
- 3-MID system w/ touch screen interface NAVI system, integrated audio functions, DVD playback, iPod, USB, Bluetooth (AVT)
- carbon fiber rear spoiler
- tail pipe finisher
di po pwede ilagay ang VGT sa present Monteros kasi you also have to replace some of the internals. It now uses high strength bearing caps and high strength aluminum alloy pistons, thinner piston rings to accomodate the cooling cavity and high load small and big end con rod bearings
price... wala pa official from the plant, although may isang dealer who is quoting the 4x2 AT*1.410M but its not official yet. both 4x4 AT and 4x2 AT have the VGT engine. 4x4 MT will have the 3-MID system, 4x2 MT is unchanged
units... is already here but it still has to wait until the Feb 24 launching. price will be announced then. same color availability, no introduction of new colors.
January 26th, 2011 06:28 PM #6
[quote=nocturnalwasabi;1664016]mga sirs... eto na final spec ng 2011 montero se:
Max Torque:350Nm/1800 - 3500rpm [SIZE=3]-- ang baba pa din nito ah. Navara 403 na eh.almost same HP.[SIZE=1]
[/SIZE]
[/SIZE]Turbocharger: Variable Geometry Turbo (developed by IHI)
Tsikot Member Rank 1
- Jul 2009
- 4,090
January 27th, 2011 09:28 AM #8
- Jan 2011
- 49
January 27th, 2011 06:28 PM #9
- Jan 2011
- 49
January 27th, 2011 07:53 PM #10mga sirs, eto lang po ang mga spec change sa 2011 montero on all variants plus the tailpipe finisher. nothing more, nothing less.
for internal consumption lang sana ng MMPC itong doc na ito. but i guess you guys deserves the info.
Tesla Philippines
