Results 101 to 110 of 2054
January 25th, 2011 09:18 PM #101
Nope Norm; I never said its CG was lower than the SF, I said it was one of the lowest in it's class. I said that its suspension has greater travel, so empty it is a lot higher than the SF as it travels up less; so empty the difference is more than 5mm. But the last bit is wrong
Explanation: The MS's Ground Clearance actually never changes unless on rough terain (like over ruts in the landscape). This is due to the fact that it has a live rear axle and the axle housing (the round bit in the middle with the diff) always remains 215mm from the road (unless one wheel is in a hole or rutt) and is the lowest point in almost all live axle 4x4s. But the body itself does go up and down and so the CG goes up and down. All vehicles with suspensions' CG changes as it is loaded.
The SF on the otherhand has independent rear suspension, so its ground clearance as well as CG changes according to weight.
January 25th, 2011 09:55 PM #102
Sounds about right guys. The press get to test drive it on the 18th of February. That is not to say some buyers won't have theirs already in their front driveway before that. Maybe my new BLACK SE will be one of them.
[SIZE=3] [/SIZE]
:harp1:
Black Is Black
I Want my Monty Black
Grey is Grey
Take that away from meeeee
What Can I doooooooo
'Cause I, I, I, I, I
Have got V G T
:harp1:
- Jan 2010
- 367
January 25th, 2011 10:09 PM #103
- Mar 2010
- 171
January 26th, 2011 06:57 AM #104
- Mar 2010
- 171
January 26th, 2011 07:00 AM #105rumors are spreading that only 4x2 at and 4x4 at will have VGT? Not sure if they will apply it to the GLX since it was only released less than a year?... But then it pays to wait sir
waiting until february 24 won't hurt you at all... ako nga 3 weeks ago pa ko commute mode eh.. haha
- Mar 2010
- 171
January 26th, 2011 07:03 AM #106
- Mar 2010
- 171
January 26th, 2011 07:13 AM #107So the 5mm difference is only applicable when you put the maximum load on the 2 vehicles. Do I get it right? Sta Fe empty it is will also be much higher than 210? right?
Geez I slightly understand only a bit hahaha... Anyway to me it looks like the montero is higher than its rivals such as fort and everest. But then it turned out like I shouldn't rely on what I see...
January 26th, 2011 09:43 AM #108
January 26th, 2011 09:50 AM #109
January 26th, 2011 10:06 AM #110
