Results 1,691 to 1,700 of 2054
Registered User
- Mar 2011
- 276
April 4th, 2011 04:40 PM #1691thanks sir Expatio for your inputs.
please bear with my english, the grammar of my fingertips is as bad as my tongue. hehe
mine is a gls-v: 4d56 model - KG4WGRPSL euro 2 compliant. your's is gt-v, i assume they are the same. tranny is different.
yes the 2.5 4d56 hi power DiD vgt was used in other country before Ph as you mentioned but the ones i saw in the net are all euro 4. their engine code is different. so i assume it is not 100% the same.
maybe there are the modification : parts/programming to downgrade it to euro 2.
those are the things that are buzzing in my head...
pang grievance komite na to ah. hehe
- Jan 2011
- 14
April 4th, 2011 05:06 PM #1693
April 4th, 2011 07:32 PM #1694
My apologies Sir Gundam. I got confused when you said 2010 DENR sticker.
So it's your GLS-V has blue smoke then; nobody else. I would take it straight back to the dealership (casa) if I was you. Where did you buy it? Sounds like a faulty erg/wastegate, seeing as it a brand new vehicle.
But do not put your problem in the same catorgory as those with normal black or white smoke. Blue smoke indicates a more serious problem.
As I said in my previous post, the trial I done today after 5 mins idle with moderate aircon yielded no smoke. Good luck at the CASA, and let us know the outcome.
As regards the downgrading here, I would say it is programned different (ecu) because the Euro diesel ULSD has virtually no sulphur per million (less than 10ppm) but extra additives as replacement because the sulphur enables lubricancy (indirectly). My guess is the sulphur here is anywhere between 350 ppm and 2000 ppm.
The extra proccessing of clean diesel requires a fairly high initial investment by refineries, but in long term would add only one or two percentage points to the price. Oil companies are not inclined to do this unless forced by legislators.Last edited by Expatio; April 4th, 2011 at 07:35 PM.
April 4th, 2011 08:08 PM #1696
April 4th, 2011 09:11 PM #1698
http://www.flickr.com/photos/59912833*N03/5525606941/
ok here is the example of VGT emetting heavy white smoketake note pati casa ganyan din kasi pinagsabay sabay namin paandarin
jeep ba nabili ko? so this is normal wow~ i even use seaoil Euro V unioil Euro IV and Unioil
- Dec 2010
- 30
April 4th, 2011 09:16 PM #1699
April 4th, 2011 09:47 PM #1700
