Page 170 of 206 FirstFirst ... 70120160166167168169170171172173174180 ... LastLast
Results 1,691 to 1,700 of 2054
    Mar 2011
    #1691
    thanks sir Expatio for your inputs.
    please bear with my english, the grammar of my fingertips is as bad as my tongue. hehe
    mine is a gls-v: 4d56 model - KG4WGRPSL euro 2 compliant. your's is gt-v, i assume they are the same. tranny is different.
    yes the 2.5 4d56 hi power DiD vgt was used in other country before Ph as you mentioned but the ones i saw in the net are all euro 4. their engine code is different. so i assume it is not 100% the same.
    maybe there are the modification : parts/programming to downgrade it to euro 2.
    those are the things that are buzzing in my head...
    pang grievance komite na to ah. hehe
    May 2004
    #1692
    Quote Originally Posted by nick_a_jose View Post
    the chirping beep is the sound we hear when we turn the key to start the car.
    i dont have this in my GLS-V
    Jan 2011
    #1693
    Quote Originally Posted by don View Post
    i see, anyway, try listening to it later when you start your car. it's just a short chirp once you turn the key, simultaneously as the engine starts.
    thanks
    Jul 2010
    #1694
    Quote Originally Posted by gundam View Post
    My apologies Sir Gundam. I got confused when you said 2010 DENR sticker.
    So it's your GLS-V has blue smoke then; nobody else. I would take it straight back to the dealership (casa) if I was you. Where did you buy it? Sounds like a faulty erg/wastegate, seeing as it a brand new vehicle.
    But do not put your problem in the same catorgory as those with normal black or white smoke. Blue smoke indicates a more serious problem.
    As I said in my previous post, the trial I done today after 5 mins idle with moderate aircon yielded no smoke. Good luck at the CASA, and let us know the outcome.
    As regards the downgrading here, I would say it is programned different (ecu) because the Euro diesel ULSD has virtually no sulphur per million (less than 10ppm) but extra additives as replacement because the sulphur enables lubricancy (indirectly). My guess is the sulphur here is anywhere between 350 ppm and 2000 ppm.
    The extra proccessing of clean diesel requires a fairly high initial investment by refineries, but in long term would add only one or two percentage points to the price. Oil companies are not inclined to do this unless forced by legislators.
    Feb 2011
    #1695
    paano po malalaman if naka valet mode yung alarm ng monty?
    May 2004
    #1696
    Quote Originally Posted by maz7487 View Post
    valet mode is when the alarm led is not blinking and it's ON all the time. that means the alarm is disabled but you can still use the keyless entry.
    Feb 2011
    #1697
    Got it. thanks sir don.
    Feb 2011
    #1698
    http://www.flickr.com/photos/59912833*N03/5525606941/
    ok here is the example of VGT emetting heavy white smoke take note pati casa ganyan din kasi pinagsabay sabay namin paandarin jeep ba nabili ko? so this is normal wow~ i even use seaoil Euro V unioil Euro IV and Unioil
    Dec 2010
    #1699
    this happen to me thrice already, when turning the key to start the car, nothing happens, i'll just hear chirping beep. so, i thought transmission is in Reverse or Drive, but it's not. when i tried turning the key again, engine starts. any idea why?
    Did this happen on cold starts (engine is cold) or just randomly during the day?
    Mar 2004
    #1700
    Quote Originally Posted by elisher0210 View Post
    naku...mapagkikitaan yan ng mga nanghuhuli ng smoke belching...
2011 Mitsubishi Montero Sport [ARCHIVED]
