Page 10 of 206 FirstFirst ... 678910111213142060110 ... LastLast
Results 91 to 100 of 2054
    #91
    OT: Yung friend ko may taxi fleet. Puro gen 2 Vios at Accent. Tibay daw nung Accent
    BTT: Hindi ba pwedeng madaliin na yang 2011 Montero Sport VGT? Dami nang nag-iintay o. hehehe. Hahaba ulit ang pila for sure..
    reply to OT: wow taxi fleet haha... sabi din niya accent? haha may vios din akong nakita 100k na mileage flooded pa daw yun..
    reply to BTT: Sana nga pwede nila madaliin hahaha, pinagrereserve na nila yun iba kaso wala pa base price tsaka launching. ang TAGAL eh.. test drove the 2010 monty okay naman na kaso kung may padating na! antay na lang.
    #92
    Quote Originally Posted by rmsoriano View Post
    yes sir, maybe the location of the center of gravity is the appropriate term and not only the ground clearance
    that's it center of gravity. im not good in physics..
    #93
    Quote Originally Posted by Expatio View Post
    That is minimum ground clearance as stated. With the MS's long travel suspension the difference is far greater in normal driving conditions. Having said that; the Monty has a very low CG for such a vehicle. To drive at minimum ground clearance you would have to load it up way past maximum load so as it will be lying on it's rubber blocks.
    I need a little bit explanation on this one. Explain this in simple math sir Expatio im confused hehe you mean to say that the monty's GC is lower since it has a longer travel suspension? / or to achieve the monty's 215mm min GC you should put on its maximum weight??? so its like the minimum ground clearance regardless of how much weight you put in it is 215?
    #94
    subscribing to this thread! my parents are planning on getting the 3.2 variant but not anytime soon... so i guess by that time, 2.5 vgt na yung makukuha nila...
    Jan 2011
    #95
    mga sirs... eto na final spec ng 2011 montero se:
    variant will be called montero sport GT-V 4WD AT
    Engine: 4D56 2.5 turbocharged and intercooled dsl
    Max Power: 178HP/4000rpm
    Max Torque:350Nm/1800 - 3500rpm
    Turbocharger: Variable Geometry Turbo (developed by IHI)
    key spec changes for the Montero GT-V:
    • 4speed INVECS II AT to 5speed INVECS II AT
    • new front grille w/ GTV emblem (Honeycomb)
    • paddle shifters
    • 3-MID system w/ touch screen interface NAVI system, integrated audio functions, DVD playback, iPod, USB, Bluetooth (AVT)
    • carbon fiber rear spoiler
    • tail pipe finisher
    di po pwede ilagay ang VGT sa present Monteros kasi you also have to replace some of the internals. It now uses high strength bearing caps and high strength aluminum alloy pistons, thinner piston rings to accomodate the cooling cavity and high load small and big end con rod bearings
    price... wala pa official from the plant, although may isang dealer who is quoting the 4x2 AT*1.408M. both 4x4 AT and 4x2 AT have the VGT engine.
    units... is already here but it still has to wait until the Feb 24 launching. price will be announced then. same color availability, no introduction of new colors.
    Jan 2011
    #96
    mga sir newbie lang po ako sa tsikot. balak ko sana bumili ng montero sport GLX next month kaya lang nabasa ko na meron pa lang lalabas na may VGT. Kailan po ba lalabas ito?at magkano po ito? Worth waiting po ba ang may VGT version na iyan? Thanks and God Speed to all for you.
    Sep 2009
    #97
    Quote Originally Posted by normyline22 View Post
    alam ko nga din ngayon ang meeting dun eh jan 25 may thread akong nakitaan na jan25 meeting hahaha... sana kahit price tapos sneak peek ng specs... tapos kahit na march pa roll out pwede na magdown =)
    haha.. ano ba yan ung SA ko talaga dami promises e. kung march pa labas bibili na ko haha.. may promo pa naman SE ngaun un lang wala na mga kulay. kakainis. sabi nia sa feb. 24 daw launching baka lumabas na daw un?? gulo gulo hehe..
    Jan 2011
    #98
    Quote Originally Posted by nocturnalwasabi View Post
    • paddle shifters
    What about the mt variants?
    Jun 2007
    #99
    Isn't this supposed to be 400nm?
    May 2004
    #100
    Quote Originally Posted by spotdog11 View Post
    +1 interested if the 4x2 mt will also be vgt powered...
    for the GLS a 20k increase is tolerable... yung pila kaya mahaba din?
2011 Mitsubishi Montero Sport [ARCHIVED]
