Results 1,261 to 1,270 of 1362
- Sep 2005
- 224
September 4th, 2011 02:09 PM #1261share ko lang upgrade ko....very simple lang silicone key cover for our asx or montero key. pm me
September 6th, 2011 02:12 AM #1262
How come may naka lagay na cruise sa may bandang tachometer? tabi ng turning left light? wala namang cruise control ang montero db?
- Sep 2005
- 224
December 16th, 2011 09:34 PM #1264
- Dec 2011
- 1
- Sep 2011
- 626
May 24th, 2012 12:12 AM #1266
- Oct 2011
- 26
May 28th, 2012 06:43 PM #1267Question po sa MS sport Gurus:
Has anyone experienced nasira kaagad yung upper ball joint? 2010 Model na 2.5 GLS. Pina check ko sa mga mekaniko dito sa office kasi may naririnig kaming tunog kaming from underneath, after thorough inspection they found that the upper balljoint is already busted.
Sa tingin ko parang maaga pa para masira yung part na yun, The car only travels from Bacoor, Cavite to Paranaque (V.V) everyday.
Seldom used in long drives or out of town trips.
Need your inputs. Thanks.
- Jun 2011
- 130
June 30th, 2012 05:54 PM #1268Mga sir, my nag try na ba na i-block ang EGR ng Montero, and whats the rusult?
- Jun 2011
- 130
June 30th, 2012 06:11 PM #1269Montero has double wishbone front suspension and this kind of suspension is prone to ball joint break down. These are not durable as Mcperson strut suspension used in most Japanesse cars and rally cars. Pero mas maganda ride ng double wishbone. Alalay lang sa lubak, para mag tagal. Fitting greasing every 15kms is important.
June 30th, 2012 06:19 PM #1270
Because the models with cruise use the same cluster. Eliminates the need to produce different instruments for different models, thats pretty much standard on todays cars. Even the rear foglamp icon is there on models not equipped. On models with cruise, the icon illuminates when you activate cruise control.
Tesla Philippines
