Page 242 of 302 FirstFirst ... 142192232238239240241242243244245246252292 ... LastLast
Results 2,411 to 2,420 of 3019
    May 2011
    #2411
    Quote Originally Posted by Noel Salisipan View Post
    Size 17" enkei, 22kg.
    to add up:
    Tires: Dunlop SP Sport 270 215/60/17
    Wheels: Enkei 17x6.5 5holes x 114pcd offset 46:
    #2412
    Quote Originally Posted by Optimusprime View Post
    thank u sir noel..
    Ok Bro.
    Goodluck sa rim hunting mo.(smiley)
    Nov 2003
    #2413
    Quote Originally Posted by skybison View Post
    to add up:
    thank u sir sky..hmm mukhang makipot sya ng konti..pero baka it could fit..
    - - - Updated - - -
    to add up:
    May 2011
    #2414
    we can test fit if you want. Nasa sala lang yun oem wheels & tires ko (freshly detailed including the tires! haha) BUT no plans in selling yet. Approx 2,000kms+ lan tinakbo nun when i upgraded, amoy bago pa.
    PM na lan tayo in case. ;)
    #2415
    to add up:
    Sky, same ba naging conversion nung stock mong gulong dun sa bago specially dun sa height?
    Worry ko kasi sa gulong ko pag na-flat in the middle of my journey dahil hindi the same ang height ng 245/45/19 sa reserba na oem.
    Ikaw, paano set up mo pag na-flat?
    #2416
    bro, yung 19s mo and oems eh wala pang 7mm ang difference on each side, i dont think it will make "kabig" at all.
    #2417
    Quote Originally Posted by zix888 View Post
    So, ok lang bro kung sakaling ma-flat yung isa sa harap at palitan ko ng reserba. Meaning oem vs yung mag 19"?
    #2418
    of course, just make sure na yung oem spare mo eh at least 34psi para halos tumabla sa 19s mo. so dapat check mo palagi din yung reserba mo
    Aug 2012
    #2419
    Skybison, have you managed to change the settings? I managed to install and activate Lexia and PP2000, but I can't activate Diagbox, it always ends with an activation error. Also, I can't change any settings in Lexia because it can't be written/saved without a code (03114 doesn't work). Have you found a code that works?
    #2420
    I see, ganun na nga ang gagawin ko, sa tire pressure ko na lang babawiin.
    Thanks uli Zix.
2010 Mitsubishi ASX Crossover
