Page 123 of 302 FirstFirst ... 2373113119120121122123124125126127133173223 ... LastLast
Results 1,221 to 1,230 of 3019
    #1221
    sapak aabutin ko kay esmi if i go at that speed. sa macapagal pa nga lang, 60kph speed limit, hindi ko namamalayan na 100kph na pala ang takbo ko, ayun, nagigising ako sa sapak ni esmi tapos balik na sa 60kph.
    Ang bait mo nman bro, at tapang nman ni Mrs mo!he3
    Oct 2011
    #1222
    Quote Originally Posted by Noel Salisipan View Post
    ASC switch, 4WD shift knob (sa Monty e lever-stick), auto folding side mirror upon lock, 7-air bags, auto leveling yung HID-lamp. sa high end na ng monty yan bro.
    Pag hindi kasi GTV e wla nung navsat.
    I like the auto-folding side mirror feature.
    Oct 2011
    #1223
    I think the ASX is assembled/manufactured in Japan whereas Monty is assembled/manufactured in Thailand.
    #1224
    Let me re-post why asking that question is pointless...
    Thanks Gh!
    What is your rpm at that speed (195kph)?
    NOTE: CVT tranny = is a transmission that can change steplessly through an infinite number of effective gear ratios between maximum and minimum values. This contrasts with other mechanical transmissions that offer a fixed number of gear ratios. The flexibility of a CVT allows the driving shaft to maintain a constant angular velocity over a range of output velocities. This can provide better fuel economy than other transmissions by enabling the engine to run at its most efficient revolutions per minute (RPM) for a range of vehicle speeds. Alternatively it can be used to maximize the performance of a vehicle by allowing the engine to turn at the RPM at which it produces peak power. This is typically higher than the RPM that achieves peak efficiency
    Read more: http://tsikot.com/forums/mitsubishi-...#ixzz1gNZvpF30
    Anyway, thanks. But the answer doesnt really address to my concern!
    Oct 2011
    #1225
    sinabi mo pa brad. katabi ko palagi si esmi sa tsikot. pinagdududahan agad ako pag mag drive ako mag isa.
    #1226
    Yup!
    Ano pala car mo Bro?
    #1227
    Hehehe!
    Pero pag luma na car e ok lang, di ka na uusisain! ako, mawala lang sa parking lot e hinahabol na ako ng text o tawag sa Pon.
    Kaya mas ok pa pag may lakad tpos yung luma ang gamit!
    #1228
    Yup, this is nice lalo na pag city parking at kahit sa malayo ang tanaw e alam mong naka-lock yung car!
    Oct 2011
    #1229
    Indeed bro. sana may feature din na auto close ung door window tulad sa Ford.
    Oct 2011
    #1230
    I was thinking of an SUV smaller than ASX. I know that Tucson, Rav4, CRV and Sportage are definitely much bigger. How about Escape and Forester is it almost same size with an ASX?
2010 Mitsubishi ASX Crossover
