Results 3,011 to 3,019 of 3019
BANNED BANNED BANNED
- Sep 2014
- 8,492
November 22nd, 2019 12:45 AM #3011Hirap kasi change ng brake fluid, parang hinde exact science, meron tiga-bomba dopat sa driver side pero minsan may hangin pa din
sayang brake master mo, pinalitan kahit Hindi sira.
sponginess can be felt also with a worn down suspension part, I'm guessing ball joint Yan. ano ba Yan? mcperhson or wishbone. if McPherson try to have the lower ball joints replaced, pag wishbone, replace both upper and lower ball joints. bale x4 yun ha.
check your tires also, baka underinflated or Mali ang pagkakalbo, replace all na din since 2010 pa yan.
and if replace ball joints, pa-check mo tie rod and rack end kung may play. per my experience, dapat sabay pinapalitan eto along with the tires para sa balik Dati na feel ng car , while you're at it check the stab links and bushings na din
- Jan 2007
- 2,452
November 22nd, 2019 02:37 AM #30121) ABS brakes still need to be bled. IMO strike out na yung shop that told you they can't be bled, that's obviously dumb.
Bleeding ABS Brake Systems
2) Old rubber brake lines there are two schools of thought on this. One is that they're good enough, the other is that they eventually expand, making stainless-steel braided lines a worthwhile upgrade. Personal experience I really liked the feel of steel braided brake lines.
- Sep 2014
- 8,492
November 22nd, 2019 08:53 PM #3013takot lang yun mekaniko ng talyer na yun,
pag binaba kasi yan brakes at kinumpuni anjan ang ABS sensor. usually, disconnect lang yan parang port ng ilaw ng bulb.
malamang nakasira yun talyer na yun ng ABS Sensor, baka nadaganan or natamaan ng tools habang nagkukumpuni ng preno, kaya ganun sinabi nila.
wag kasi kayo magpapagawa sa mga talyer na walang lifter, magnet talaga sa kapalpakan yun mga ganun talyer.
- Mar 2003
- 255
November 22nd, 2019 09:43 PM #3014Will just clarify...
According to shop (roadstar Katipunan), bleeding has to be done in Casa due to the ABS sensor... it will continually pump the fluid.... if they do it
My second shop was eldorado in project 4 (or cubao area)
Both shops were recommended, but I’m not satisfied with their service .... or lack of... though same with my existing CASA
So I’m still in limbo how I will proceed...
Take note I have nothing against the recommended shops... I’m sure they are good... just want to fix my ASX without guessing
Thanks
- Sep 2014
- 8,492
November 23rd, 2019 02:03 PM #3015bago gawa na kasi brake master mo, so closed system ang hydraulics, kung may leak pa yan, kung may aso kayo sa bahay nyo siigurado patay na yun if hinde mo nakikita kung nag leak ang brake fluid mo, kasi i lick nya yun
if you are after how it rides before when it was younger, thats why you described is spongy. I would recommend na tignan mo na na ang ibang part sa suspension system kasi they all work together. pag hinde ganun kakapit ang preno as before, somethig is worn out kaya di makapit sa harap.
The problem with mechanics and talyer with lifters, they really guess on the suspension system, so kelangan mo na mag decide on your own. A car with that age, ball joint yan. i consider ball joints kasi as like sparkplugs or fuel filter, kelangan palitan every 5 years. Madali lang gawin yan, maybe 1-1.5 hours work sa gasolinahan.
Now if i were you palitan mo na lahat ng dapat palitan sa suspension since bago na din brake pads , brake master at bago bleed fluid mo, para maganda and like new ulit takbo. Yes, even the tires if you have the budget
November 23rd, 2019 04:19 PM #3016
Onti onti ba nauubos ang brake fluid?
- Jan 2007
- 2,452
November 23rd, 2019 06:35 PM #3017
November 23rd, 2019 09:02 PM #3018
Ginawa ko sir bumili ako nun bleeder hose with one way valve. Although pwede naman hose lang na naka lubog yun exit end sa brake fluid, gusto ko lang try out yun may valve.
Few days ago nag palit brake fluid ako nun sasakyan namin (Vios lang naman) kasama ko si misis. Si misis taga tingin pag may bula at nun level ng brake fluid. Minsan sya mag pump ng pedal pag nag double check ako.
Although dalawa kami is basically kaya naman ng isang tao.
Drove the car yesterday for 20KM so far no issues.
- Nov 2009
- 1,756
January 25th, 2020 06:10 PM #3019
Tesla Philippines
