Results 11 to 20 of 154
November 9th, 2006 05:44 PM #11
Tsikot Member Rank 4
- Jan 2003
- 2,979
November 9th, 2006 06:01 PM #12hmmm.... di ba ang airplane eh propelled through the air and not using the road? tingin ko lilipad pa rin since support lang naman ang function ng gulong... agree ako sa post ni niky... trick question to
November 9th, 2006 06:12 PM #13
November 9th, 2006 06:18 PM #14
November 9th, 2006 06:23 PM #15
- Jul 2005
- 199
November 9th, 2006 06:24 PM #16yes! a big yes! lalo na kung VTOL (vertical take-off and landing) ang aircraft like the harrier hahaha!
levity aside, i agree with niky.
November 9th, 2006 06:27 PM #17
But the airplane isn't wheel driven. It's driven by pushing against the air, not the road.
Here's another way to put it... I'm holding a rope attached to a wall in front of me, with my feet touching a conveyor belt... I move forward by going hand-over-hand along the rope with roller skates on, and standing on the conveyor belt.
The conveyor is moving in the opposite direction at the same speed as my roller skate wheels... or better yet, faster than I can pull. The question: is it possible for me to move forward?
Is it impossible for a water skier to pull himself forward along a line, with the water moving under him faster than he can go hand-over-hand?
C'mon. The bigger question is: Why would you say I can't? :hihihi:
November 9th, 2006 06:36 PM #18
Again, the conveyor is supposed to only match the plane's speed, and it only acts on the plane's wheels. Thus, the wheels are moving twice as fast, but the plane is still moving at the same speed.
Duh, my mistake, the answer should be NO... because by the time the plane has reached its 150 mph take-off speed, the wheels are going 300 mph, and they'll overheat, blow-out, and the wheel hubs will catch in the conveyor belt, causing it to seize, and tons of metal airplane and steel-plated conveyor belt strips will be flying through the air at speeds of over 100 mph...
I can just imagine it now...
Again, trick question... because the conveyor moves with speed, and speed does not equal force. That's why a water skier can be doing 40 mph over the water while only holding on to a line with arms that can't even push him at 10 mph... because he's exerting more force on the line with his arms than the water is exerting on his feet.
- Jul 2005
- 199
November 9th, 2006 06:39 PM #20in short you will need an anchor to stop a plane from taking off not some some sort of conveyor belt.
