Page 4 of 4 FirstFirst 1234
Results 31 to 38 of 38
    Dec 2009
    #31
    Switch ng ceiling light gagamitin not in appliances.
    Disconnect (cut one of the AC line from the ceiling switch) first one of the terminal of the light ceiling switch to from the AC line then tap it to the leftmost terminal of your gadget. That will leave one of the AC line hanging so u better cover that line covered with electrical tape
    Note if youre not an electrician, dont attempt to do it this way. Ditch the ceiling switch
    Connect the middle terminals of the gadget together
    Tap one of the 220AC line to the left AC line of the gadget then tap the other 220AC line to the right AC line of the gadget
    Now that makes it 2 switch in series before the load gets attached to the 220AC line
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Jan 2009
    #32
    I think ang problem is, if understood the TS correctly, ay walang 'partner' na 220V sa loob ng existing light switch.
    Yung "switch" terminals ng timer should replace the existing switch. However, in order for the timer to work, it also needs to receive power from a 220V source. Kung wala syang makuhang 220V source sa loob ng switch junction box, he will likely need an electrician to lay the wire for him.
    Otherwise, medyo ghetto kalalabasan kung latagan nya ng wires papunta sa 220V outlet.... pangit na tignan kung nakalitaw yung wires sa wall.
    Dec 2009
    #33
    ^that should be the ideal thing to do, replace the switch for the light ceiling with the timer switch but he did clarify that the load is the switch..so that makes it a redundant switch
    The load should be the light with timer switch replacing the wall mount switched where the light was initially connected from
    Jan 2009
    #34
    Proper method:
    Ghetto method:
    Excuse the crude sketch.
    Typically, your home would've been wired as such (BROWN wires in the sketch). In order to use the timer (assuming it requires 220V AC to operate, NOT 12V DC), additional wirings are needed (PINK wires) to connect to a 220V AC source.
    Dec 2009
    #35
    Shadow do you intend to use the existing wall mount switch of the ceiling light as a bypass switch to the timer switch?
    #36
    No. But since it's too complicated, I think it's easier to teach na lang yun maid to turn off and on the lights sa time na gusto ko. [emoji23]
    Jun 2008
    #37
    good decision or hire ng marunong na electrician madali lang sa kanila yan. mahirap ng magmarunong pagdating sa kuryente. safety first.
    Sent from my SM-G950F using Tsikot Forums mobile app
    Jun 2012
    #38
    Install a motion sensor with IR detector.
How do you wire a wall light switch to this timer?
