Results 421 to 430 of 1411
- May 2008
- 1
June 1st, 2008 09:19 AM #421
- 53
June 18th, 2008 07:05 PM #422Mga gurus, where can i get a the following: Environment, Health, Safety Requirements Certificate?
July 15th, 2008 11:28 AM #423
July 15th, 2008 11:33 AM #424
Tanong din po. Can you suggest:
1) a good screen door maker para sa main entrance
2) a good mirror maker, yong medyo makapal naman na mirror not like those being sold in ACE or Handyman
- Jan 2007
- 86
July 15th, 2008 08:16 PM #425
- Jul 2007
- 452
July 15th, 2008 08:41 PM #426Am new here in the country and was wondering. If you have a lot of a certain size someone said you must allocate X amount of pesos per sqm for building to the architect. Now lets say that you dont construct on entire lot but make a big gardern. Does that same rule apply? For example you intend to build on a lot of 700sqm. If you only allocate 400 sqm of it to the house structure should you still compute against the 700sqm?
July 15th, 2008 09:24 PM #427
Running rate yata ngayon is about P25k per square meter. What's included are all covered areas. So essentially, floor area (not lot area). Kung covered parking, covered utility area, servants quarters or outhouse, they usually include that in the computation.
It's more of a guide rin lang.
July 15th, 2008 10:16 PM #428
Ang mahal na talaga,- P25K/sqm.... tsk tsk tsk.... And this is floor area, so if you have a second floor, and a third floor/attic then they count in the total floor area....
6404:pump:
July 16th, 2008 09:00 AM #429
Naturally cost per square meter can vary depending on materials, design, non-liveable areas and options and the cost is around 25% higher than the floor below (if both floors are identical in construction.)
- Jul 2007
- 452
July 16th, 2008 09:26 AM #430Wow 25k/sqm is expensive. And that is based on FA right? Not LA? Plus it doesnt include ba items like Toilets? or is that factored in?
Since Materials come into play the 25k computation is high end materials? What would the percentage dropes be for subsequent lower end materials?
