Results 611 to 620 of 902
- Jul 2013
- 2,450
August 8th, 2014 03:35 PM #611Nice one leinaghtan.
What soundproofing material did you use?
Is it just an exhaust pipe extension?
August 8th, 2014 05:23 PM #612
- Jul 2013
- 2,450
August 9th, 2014 12:33 AM #613
- Jun 2006
- 1,139
August 9th, 2014 01:29 AM #614Wala palang 1800rpm na small diesel genset? All the same 3600rpm din, same as gas. At parang mas tahimik pa gas kesa disel na open type?
August 9th, 2014 06:49 AM #615
August 9th, 2014 10:06 AM #616
sir... ingat po kayo may mga kilala ako... gumawa ng sarileng enclosure... nag cause ng sunog... (10kva pataas)
sa init ng exhaust pipe kadalasan nag start ang fire.... i suggest ample space and put fire retardant foam and top it with steel screen sa area ng exhaust pipe..
August 9th, 2014 10:46 AM #617
Ok thanks for the precautions/suggestions. All areas of concern will be dealt with. Yung sa area ng pipe holding it from the panel may fireproof belt (I dont know what it is called) Yung nilalagay na holder sa tail pipe ng mga vehicles. Will still need to make minor mods sa areas where heat would mostly develop. My genset is just 4.5kva.
Posted via Tsikot Mobile app on S3LTE
- Oct 2013
- 1,181
August 9th, 2014 10:56 PM #618Basta direct coupled sir, expect a higher rpm, mapa diesel or gas, or yung mga air cooled, typical, highspeed.
Just purchased a Kubota replica made by Chingqong Golden Bow, 14 HP direct injection engine, i-drive nya sa ngayun ay 5kW na dynamo/alternator... Expected fuel cost for an 8 hour operation at around 2kW load is PhP 150.00 hehehe...
Yung direct coupled diesel na china made na sinasabi rated above 5kVA, is in real life 4kVA lang, aside from that 1 liter per hour ang consumption at around 50% load..
- Oct 2013
- 1,181
August 9th, 2014 11:05 PM #619
