Pano mo malalaman if Standby use lang?
And if contineous?
Nasa brand ba? Engine?
Printable View
time for genset function test again. dry run monthly
Sent from my SM-C900F using Tapatalk
good better ready than sorry [emoji30]
Have to send a genset or two to our offices in Bicol. Can anyone recommend a seller and models? Will probably need 3.6KVA to 5KVA.
Wala ako kilalang seller pero madami nga sa Quiapo (Evangelista St.) Doon ko binibili mga power tools ko at welding machine.
I also have a small genset (1000watts) pero sa Laguna ko na binili para malapit sa amin. Toyohoma ata yung tatak.
Most probabaly Made in China pero at least well-written yung manual in English.
Kung kukuha ka ng genset at puro China-made naman ang option, choose the one with copper windings (instead of aluminum). Mas matagal masira.
Diesel genset is also a good option although mas mahal for same capacity as gasoline genset.
Diesel gensets tend to be more quiet (lower operating RPM) at syempre mas mura ang diesel.
Yung gas genset needs proper maintenance lalo na carburetor. Pag natengga ng matagal at nabarahan ng kaunti ang jets ng carb, palyado na agad takbo.
Kaya ako lagi nag lilinis ng carb.
message mo si gm bro
Glenn Manikis | Facebook
Si *uls din yata nagbebenta
Thanks for the info guys. Ipon lang muna ako ng quotes.
