Results 631 to 640 of 902
August 12th, 2014 02:49 PM #631
no, i will not spend that kind of money on something i will use once in a blue moon. i am just actually eyeing a 2nd hand 1.5 kva unit.
August 12th, 2014 02:52 PM #632
You want a generator house to hush that vociferous genset and at the same time safe, use metal tin roofing material riveted to g.i. metal wall studs. Make a double wall system with Fiberglas noise batts for noise and heat insulation. The volume of this enclosure approximately three times the dimension of the genset in cubic meters and provide vent system capable of around ten times air exchange per minute. Also provide for exhaust extension. You can make the panels collapsible for storage.
Posted through phlpost.gov.ph
- Jul 2013
- 2,450
August 12th, 2014 07:25 PM #633
- Aug 2003
- 9,720
August 12th, 2014 08:13 PM #635
August 12th, 2014 08:42 PM #637
if you want meron ako 2" fire retardant foam ginagamit talaga para sa genset...
Posted via Tsikot Mobile App
August 12th, 2014 08:46 PM #638
or if you want and kung willing kau maghintay meron daw super silent na genset 1kva-7kva diesel check ko muna unit then kung talagang maganda mag pasok import ako... if ever... dec. 2014 pa...
August 12th, 2014 10:50 PM #640
Pwede. But a high temp auto shutdown module is better > http://generator-reviews.siterubix.c...ator-enclosure
Posted via Tsikot Mobile app on S3LTE
Tesla Philippines
