Page 27 of 91 FirstFirst ... 172324252627282930313777 ... LastLast
Results 261 to 270 of 902
    Oct 2011
    #261
    Quote Originally Posted by rollyic View Post
    hindi ba variable ang current ng aircon?
    kung invertype yes. variable ung current pero pag conventional hindi.
    Aug 2003
    #262
    mga sirs bump ko lang to...
    ano po yung recommended brands? looking for a 3 - 5kVA unit, silent type. thanks
    Aug 2003
    #263
    bumping
    Aug 2003
    #264
    bumping...
    Looking for a generator with the ff specs:
    - 5 - 6kVA range.
    - prefer diesel, but gas is ok
    - easy start + manual start available
    - silent type(optional)
    Ano pong magandang brand, one that is serviceable with plenty of parts?
    Regarding the noise: is it possible to DIY an insulation enclosure for the generator?
    Malaki ba price diff between normal and inverter-type engines?
    thanks
    Jun 2011
    #265
    Power generators Usually last for 20k hours... On prime power...
    Jun 2011
    #266
    Diy enclosures.. Pwede
    But I don't recommend... Too many factors to consider...
    Pag Mali ang pagkagawa.. It can start a fire, overheating problems, problems sa pag service sa unit.... Accessibility...
    Oct 2011
    #267
    Sir manikis, pagka continuous ung genset mo more than 20k na ba un?
    Sent from my iPad using Tsikot Car Forums
    Jun 2007
    #268
    sir glenn, is it true na possible i-convert ang car engine into a generator set?
    sabi kasi ng pinsan ko, bili na lang daw kami ng diesel or gas engine tapos i-convert nya.
    if possible, anong pros & cons non?
    thanks in advance.
    Oct 2011
    #269
    Hmmm.... magiging compatible kaya ang alternator sa car engine sir? wala pa akong nakitang nag convert.
    Aug 2003
    #270
    Sir maganda po ba yung kipor? a dealer once told me this is the #2 genset brand in China, class "A" naman daw. Di kaya problema sa piyesa?
    Tried looking for Honda, they don't seem to have any (locally) beyond 3kVA.
    Also tried looking at Kubota...parang wala naman less than 10kVA :p
    Re car motor as generator: with enough engineering knowledge and machine shop skills, pwede siguro, but considering even a lowly 40hp engine, that's around 29kVA right? Unless you have that kind of load, parang sayang lang sa fuel.
Generator sets
