Page 13 of 19 FirstFirst ... 391011121314151617 ... LastLast
Results 121 to 130 of 182
    the limiting factor in eyeglasses is the lens.
    at times, the establishment has no stock of the required grades, and has to order them pa.
    blessed are those with simple grades of their eyes.
    the last time i had glasses made, because my old frame got broken,
    i brought my old lenses; it took them a few minutes only, to grind them to size and install them in my new frames.
    true. my set will arrive in 2 weeks pa.
    welcome back stocky!!!!! Naalala ko kayo dalawa ni doc ayaw nyo kay angel locsin kasi lumobo!!!!
    check mo nga ito stock kasi naiintirga ako sa endmyopia.org. Nabasa ko ito sa mga homies ko international health forum.
    firstly, what is your prescription now ? for example it is -4.5 each eye.
    then you should drop to -4 in each eye and use them for everyday use.
    secondly, you need another pair of glasses for computer work and close up work. this can be about -2.5
    If I was to summarise the entire method on Endmyopia(R) - Improve Your Eyesight With Science & Habits,
    it would be to make sure everything you do has a mild blur to it. If there is too much blur , then the eye will not improve. Like weightlifting weights that are too heavy.
    so a basic example.
    -4 in each eye.
    start using -3.5 for everyday use.
    use -2.5 when at a computer .
    gradually drop as you feel your eyesight improve. this take 4-6 weeks.
    0.25 is probably the safest drop , I jumped from -4 to -3.5 and it was too much
    what are you using for close up reading ? i went from -2.5 to -1.25
    If you could find an open minded optometrist, yes, show them endmyopia.
    You want a normal eye test.
    for example you are -4 both eyes, start by finding the blur point of text and trying to clear it by finding your focus point.
    the principles of eyesight improvement do not change.
    Naiintriga ako sa focus point.
    #123
    i also ordered a whole new set, so's i have a spare.
    they also advised me, 1-2 weeks waiting time.
    limang araw na lang...
    #124
    so a basic example.
    -4 in each eye.
    i have been entrusting my lens grades to the specialist all my life.
    they measure it for long distance, and they measure it for reading / computer.
    bifocals.
    i am satisfied.
    so a basic example.
    -4 in each eye.
    hi kags the controversial.
    I haven't been following this person ehehhe. Are there hormonal therapies that can help her ba?
    excellent link, I may need to "read" this later on. Bookmarked*
    my brother just got diagnosed with nearsightedness at least its less than 40/40.
    Got my specs. 13g total weight.
    The transitions pretty good
    #127
    that's great!
    so, you also have those digital weighing scales?
    i got mine from shoemart. instant gratification.
    that's great!
    Si senyor. I got the scale on amazon. Mas mura sya kesa sm. branded yun scales sa sm.
    #129
    when i got mine,
    i as so aliw,
    i was weighing every other common object in the haus.
    ang bigat pala ng seiko sea urchin! 162 grams! in contrast, my titanium seiko weighed only 69 grams.
    i also got digital bathroom scales. it was so accurate, my before-and-after-jingle weights differed by 300 grams. exactly how much my 300 ml of urine weighs!
    OT.
    when i got mine,
    i as so aliw,
    OT.
    Ahhahahah that jingle weight is weird af. I did weigh my shyt too in the name of science.
eyeglass lens & frames
