Results 11 to 20 of 57
September 5th, 2018 02:05 PM #1
How to Use a Torque Wrench - How to Tighten Lug Nuts
In this article, it tells you why you shouldn’t use an extension bar, a pneumatic wrench or jumping on the wrench to tighten it.Last edited by bloowolf; September 5th, 2018 at 02:07 PM.
September 5th, 2018 05:02 PM #2
Thank you guys, now I know that I was applying 145 lbs/ft or a little less maybe cause the stock wrench is about 10" only. I quick internet search say 80 lbs/ft only or around 40 kgs force in my case.
Now, now I have to reduce my weight by 25 kgs.
September 5th, 2018 05:38 PM #3
September 9th, 2018 06:56 AM #5
unless may nararamdaman kang pag wiggle. Otherwise hindi kailangan yun.
- Mar 2018
- 263
September 4th, 2018 06:39 PM #6I normally use a metal pipe to extend the wrench. It will increase the torque and help loosen the nut.
Sent from my ONEPLUS A3003 using Tapatalk
- Feb 2014
- 2,658
September 5th, 2018 10:36 PM #8
- Jan 2008
- 4,726
September 5th, 2018 10:45 PM #9
