Results 61 to 70 of 80
August 27th, 2015 03:26 PM #61
- Aug 2015
- 6
October 7th, 2015 09:45 AM #63
newbie question: Is Rota safe to use? How is it compared to genuine rims from Rays, Vossen and momo? How can Rota be priced so low compared to those (aside from import taxes of course)? How safe are copy rims?
How about compared to stock aluminum rims say from Nissan and Honda?
I have 17" stock aluminum rims (nissan sylphy, 5H PCD114) and I'm curious if going Rota would be an upgrade or a downgrade. Thanks in advance.
October 7th, 2015 09:59 AM #64
- May 2015
- 280
October 7th, 2015 10:11 AM #651. It should be safe to use but you'll have to mind potholes if you install with them low profile tires, more so if you're on genuine rims.
2. Genuine rims are made from high-quality light weight materials. These genuine rims are always lighter than copies. What made them more expensive is the use of higher quality materials and the process of making them (forged, 3-piece, etc) plus the design RND that is part of the manufactuing process. Rota only copies whatever the design is, using cheaper materials.
3. Stock alloy wheels are usually heavier than Rotas. You will feel a slight gain in performance(handling, stability, acceleration, etc) of your car if you UPGRADE to even ROTAs because they are lighter and wider(usually). Lighter set of wheels are good because it decreases unsprung weight. Lightest Rota is ROKU then TITAN.
4. Last but not the least is aesthetics. Your car will be prettier and more unique with aftermarket wheels.
Hth.
- Feb 2014
- 33
October 16th, 2015 01:46 AM #66
October 16th, 2015 07:06 AM #67
October 18th, 2015 07:35 PM #68
Saan ba may resller ng Rota SS10-F balak ko sana install sa innova kaso kakatamad pumunta sa rota's main office na sinaggest ng kaibigan ko
October 18th, 2015 08:58 PM #69
- Aug 2015
- 5
November 5th, 2015 06:54 PM #70[ATTACH=CONFIG]29839[/ATTA
hi sirs im looking for 20's sna na mesh type mags like this one for mitsubishi asx.. thanks
